1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: measComp 2-1 and TC32
To: 'John Dobbins' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Sep 2018 20:27:49 +0000
Hi John,
Ø  Is the TC32 supported by PROD_IOC_LINUX measCompApp ?
Yes, but as the R2-0 release notes say, it has not been tested on Linux yet (because I don’t own one).
Ø  The TC32 is connected via ethernet and configured to be Board# 1
I assume you mean it was configured as Board #1 with InstaCal?  On Linux the InstaCal assignment of board numbers is not used.  Rather you need to add a cbAddBoard() command to your startup script before the call to MultiFunctionConfig().
Here is the difference between st.cmd and st.cmd.linux in iocBoot/iocETC for the E-TC thermocouple module.
corvette:measComp/iocBoot/iocETC>diff st.cmd st.cmd.linux
9a10,11
> cbAddBoard("E-TC", "164.54.160.218")
You should add this line to your st.cmd file where xxx.xxx.xxx.xxx is the IP address of the device.
cbAddBoard("E-TC32", "xxx.xxx.xxx.xxx")
The first cbAddBoard command will define board #0, the second will define board #1, etc.  So you will use board=0 in MultiFunctionConfig().
Let me know if this works for you.
From: [email protected] <[email protected]> On Behalf Of John Dobbins
Sent: Wednesday, September 19, 2018 2:38 PM
To: [email protected]
Subject: measComp 2-1 and TC32
I am confused about the status of support for Measurement Computing TC32 on linux.
In
measComp-R2-1/measCompApp/src
the Makefile includes the lines:
PROD_IOC_WIN32 += testTC32
testTC32_SRCS += testTC32.c
ifeq (win32-x86, $(findstring win32-x86, $(T_A)))
testTC32_LIBS += cbw32
else ifeq (windows-x64, $(findstring windows-x64, $(T_A)))
testTC32_LIBS += cbw64
endif
but there is not a testTC32 IOC for linux. Is the TC32 supported by PROD_IOC_LINUX measCompApp ?
I tried running measCompApp with a single thermocouple.
Here is the IOC console on start-up:
jad22@erp201 $ ../../bin/linux-x86_64/measCompApp st.cmd
< envPaths
epicsEnvSet("IOC","iocTC32")
epicsEnvSet("TOP","/nfs/erl/online/epics/R3.15.5/support/measComp-R2-1")
epicsEnvSet("SUPPORT","/nfs/erl/online/epics/R3.15.5/support")
epicsEnvSet("ASYN","/nfs/erl/online/epics/R3.15.5/support/asyn4-33")
epicsEnvSet("CALC","/nfs/erl/online/epics/R3.15.5/support/calc-R3-7-1")
epicsEnvSet("STD","/nfs/erl/online/epics/R3.15.5/support/std-R3-4-1")
epicsEnvSet("MCA","/nfs/erl/online/epics/R3.15.5/support/mca-R7-7")
epicsEnvSet("BUSY","/nfs/erl/online/epics/R3.15.5/support/busy-R1-7")
epicsEnvSet("SSCAN","/nfs/erl/online/epics/R3.15.5/support/sscan-R2-11")
epicsEnvSet("AUTOSAVE","/nfs/erl/online/epics/R3.15.5/support/autosave-R5-9")
epicsEnvSet("SNCSEQ","/nfs/erl/online/epics/R3.15.5/support/seq-2.2.5")
epicsEnvSet("MEASCOMP","/nfs/erl/online/epics/R3.15.5/support/measComp-R2-1")
epicsEnvSet("EPICS_BASE","/nfs/erl/online/epics/R3.15.5/support/base-3.15.5")
dbLoadDatabase "../../dbd/measCompApp.dbd"
measCompApp_registerRecordDeviceDriver pdbbase
# Configure port driver
# MultiFunctionConfig(portName,        # The name to give to this asyn port driver
#                     boardNum,        # The number of this board assigned by the Measurement Computing Instacal program
#                     maxInputPoints,  # Maximum number of input points for waveform digitizer
#                     maxOutputPoints) # Maximum number of output points for waveform generator
#MultiFunctionConfig("TC32_1", 0, 1048576, 1048576)
MultiFunctionConfig("TC32_1", 1, 0, 0)
2018/09/19 15:13:53.411 MultiFunction::MultiFunction error, unknown board type=0
dbLoadTemplate("TC32.substitutions")
asynSetTraceIOMask TC32_1 -1 2
#asynSetTraceMask TC32_1 -1 255
#< save_restore.cmd
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Sep 19 2018
2018/09/19 15:13:53.916 MultiFunction:writeInt32, port TC32_1, function=14, ERROR writing 1 to address 1, status=1
2018/09/19 15:13:53.916 TC32:Ti0TCType devAsynInt32::processCallbackOutput process error
#create_monitor_set("auto_settings.req",30,"P=TC32:")
epics> dbl
TC32:Ti0Scale
TC32:Ti0TCType
TC32:Ti0Filter
TC32:Ti0
epics> dbpr TC32:Ti0
ASG:                DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: TC32:Ti0      RVAL: 0             SEVR: NO_ALARM
STAT: NO_ALARM      SVAL: 0             TPRO: 0             VAL: 0
epics>
InstaCall reports a reasonable temperature.
I am completely new to this device and to Measurement Computing support.
Any help appreciated.
John Dobbins
Cornell Univesity
measComp 2-1 and TC32 John Dobbins
Prev: measComp 2-1 and TC32 John Dobbins
Next: Re: asynPortDriver and read/write access to record fields Loeher, Bastian Dr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: https://ics-web.sns.ornl.gov/css/nightly/ down? Silver
ANJ, 23 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
