1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: CSDataQuick 1.1 Release
To: Epics <[email protected]>
Date: Mon, 1 Oct 2018 19:28:16 +0000
Although a minor release, it has packed in a lot of changes. Two of them are backwards incompatible:
1. The “dynamicAttribute” and “limits” properties, if used in qml designer, created alias properties
   like “dynamicAttribute_channel”, “limits_preSrc”. This was used as a workaround to use complicate properties
   in qml designer. In the version the qml designer support has been implemented properly so that this workaround
   is removed. This means that these properties have to replaced, e.g.
      dynamicAttribute_channel -> dynamicAttribute.channel
      limits_preSrc -> limits.preSrc
2. ADLViewer is renamed to Viewer, because it gets support of extra display formats like EDL and UI.
See the full list of changes here, http://epics.web.psi.ch/software/CSDataQuick/docs/releases.html
The binary packages can still be found here http://epics.web.psi.ch/software/CSDataQuick. The conda packages are
also in the paulscherrerinstiute channel, but the linux-64 platform is still missing because the conda qt-5.9
now only works on rhel/cento 7.
Best
Xiaoqiang
Prev: Re: Stream device does not recognize a custom record type Dirk Zimoch
Next: RE: Stream device does not recognize a custom record type Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Stream device does not recognize a custom record type Abdalla Ahmad
Next: ADPicam problem Jörn Dreyer
ANJ, 02 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
