1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: ADPicam problem
To: tech-talk <[email protected]>
Date: Tue, 02 Oct 2018 08:59:53 +0200
Hello,
I'm currently setting up a system that uses a PrincetonImaging PIXIS camera.
As these cameras use an USB interface I have to use the latest version of the
PICAM library (5.1.2) from Princeton.
With this library the driver connects at startup but looses the camera during
the initialization phase. In the hardware setup routine the driver registers a
callback function for the PICAM_Discovery mechanism. This function seems to
loos the communication over USB with the connected camera if another thread
talks to the camera.
Has anybody else observed this behavior? I could get around this problem if I
comment out the calls to the PICAM_AdvancedRegisterForDiscovery function.
But then the driver is only able to use the first detected camera. If I would
connect two, I can not select the one I want to use.
Regards
Jörn
Re: ADPicam problem Engbretson, Mark S.
Prev: RE: Stream device does not recognize a custom record type Abdalla Ahmad
Next: Re: Stream device does not recognize a custom record type Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: CSDataQuick 1.1 Release Wang Xiaoqiang (PSI)
Next: Re: ADPicam problem Engbretson, Mark S.
ANJ, 02 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
