I believe that this is the expected behavior of that area detector. You can have multiple real or simulated cameras configured, but you can only use one at a time. One of the display elements is a menu option of the possible cameras which allows you to pick and choice which one you want active at any given time.
I do not think that any single AD allows for multiple active cameras. The controls are not made for that.
If your case, you really need to configure yours as 2 different ones, and have each manually select for the particular one the you want - which only works if you do not have 2 of the same camera type.
On Oct 2, 2018, at 02:00, Jörn Dreyer <[email protected]> wrote:
Hello,
I'm currently setting up a system that uses a PrincetonImaging PIXIS camera.
As these cameras use an USB interface I have to use the latest version of the
PICAM library (5.1.2) from Princeton.
With this library the driver connects at startup but looses the camera during
the initialization phase. In the hardware setup routine the driver registers a
callback function for the PICAM_Discovery mechanism. This function seems to
loos the communication over USB with the connected camera if another thread
talks to the camera.
Has anybody else observed this behavior? I could get around this problem if I
comment out the calls to the PICAM_AdvancedRegisterForDiscovery function.
But then the driver is only able to use the first detected camera. If I would
connect two, I can not select the one I want to use.
Regards
Jörn
- Re: ADPicam problem Jörn Dreyer
- ADPicam problem Jörn Dreyer
Re: Stream device does not recognize a custom record type Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
