1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector ADViewers R1-1 available
Date: Thu, 4 Oct 2018 12:19:50 +0000
ADViewers R1-1 is now available.  This is from the release notes:
### EPICS_NTNDAViewer
* Found a serious bug in epics-pvaclient-4.3.1.jar.  A destroy() function was not being called when it should have been.
  The result was that when the NTNDArray was not reachable (i.e. IOC not running) the broadcast search requests added
  additional copies of the same PV with time.  This caused the request to grow in size until it required many
  packets.  The network was thus flooded with broadcast packets if the ImageJ plugin ran for many hours or days without
  being able to connect to the IOC.  This was sufficient to cause VME IOCs on the subnet to be 95% CPU bound just processing
  these broadcast packets.
* Fixed the logic in connectPV() when a connect attempt failed.  This was also incorrect, and could contribute to the above
  problem.
* Marty Kraimer fixed the problem in epics-pvaclient-4.3.2.jar, which is now included in this release of ADViewer.
### pvAccess jar files
* All of the other pvAccess jar files were updated to the latest versions.
The home page is here:
https://github.com/areaDetector/ADViewers
The documentation is here:
http://cars.uchicago.edu/software/epics/areaDetectorViewers.html
The release notes are here:
https://github.com/areaDetector/ADViewers/blob/master/RELEASE.md
Prev: MeanWell RKP-CMU1 Zumbruch, Peter Dr.
Next: Using EPICS 7 on our production beamlines Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
