1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building epics base for a different location
To: [email protected]
Date: Fri, 5 Oct 2018 12:05:06 +0200
Hi Richard,
  There are two variable you can use.
  $(TOP) : where the epics base source code is
$(INSTALL_LOCATION) : where the epics "compiled" binary files and other files are.
  If there is no INSTALL_LOCATION, TOP is the same as INSTALL_LOCATION.
  Please check configure/CONFIG and CONFIG_SITE files as well.
However, the above approach doesn't fulfill what you ask. In order to achieve your approach, you may try the following procedure:
  In $(TOP) (location A)
  1) make build
  2) make install
  3) add the location B in CONFIG_SITE
   echo "INSTALL_LOCATION=${LOCATION_A}" > configure/CONFIG_SITE.local
  4) make install
  HTH,
  Han
On 10/5/18 10:43 AM, Lucock, Richard M wrote:
     I want to build an epics installation in location A but then
copy it to location B for actual use. I can't find a suitable config
variable for this - can anyone point me in the right direction ?
     Richard
Re: Building epics base for a different location Jeong Han Lee
Building epics base for a different location Lucock, Richard M
Prev: PV alias with logical names Bo Jakobsen
Next: RE: PV alias with logical names Freddie Akeroyd - UKRI STFC
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Building epics base for a different location Lucock, Richard M
Next: Re: Building epics base for a different location Jeong Han Lee
ANJ, 05 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
