In general it is a good idea to avoid writing device support if you can avoid it. From your example it sounds like you want to send a string to a device, read a string response, and convert the string response to a number. That is a very common thing to do. There is an existing device support called streamDevice which will do exactly that. It means you don't need to write any C code, only a streamDevice protocol file:
http://epics.web.psi.ch/software/streamdevice/doc/
If you have already considered streamDevice and still want an answer to your specific questions, please let us know.
From: [email protected] <[email protected]> on behalf of ori spokoini <[email protected]>
Sent: Sunday, October 7, 2018 4:38 AM
To: [email protected]
Subject: about talking to other record in device support and converting string to int
hi
assume i have record like that
ecord(stringout, "tlm") {
field(OUT, "pro NPP NMS")
field(SCAN, "I/O Intr")
field(FLNK, "pro PP NMS")
record(stringin, "pro") {
field(INP, "$tlm.VAL")
field(SCAN, "Passive")
field(DTYP, "devsup")
field(FLNK, "sum PP NMS")
record(longin, "sum") {
and i want to change the value the longin record from devsup can i do it ?
somthing like :
int devfunc2 (longinRecord *x){
x->val=30;
return 0;
and another question :
how can transfer number from stringin to calc record
tx
- about talking to other record in device support and converting string to int ori spokoini
CA SERVER setup and build אייל פרחי/Eyal Farchi
Re: CA SERVER setup and build Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
