1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA SERVER setup and build
To: אייל פרחי/Eyal Farchi <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 7 Oct 2018 22:12:40 +0000
> I'm trying to set one machine as server  and one as client and read pv's values with no success.
What you are doing should work.  Please do the following:
- On the server machine, start the IOC (server).  At the IOC prompt type this command and send the output:
dbl
That will show you a list of the records in the IOC.  Chose one of those records for testing.  I am calling that myTestRecord in my following instructions.
- On the server machine in another terminal window type this command and send the output:
cainfo myTestRecord
- On the client machine type this command and send the output:
cainfo myTestRecord
The most common reason for this to fail is if you are running a firewall program on either machine.  On Linux the common firewalls are iptables and firewalld.  You either need to disable the firewall or add exceptions for ports 5064 and 5065 on both UDP and TCP.
From: [email protected] <[email protected]> on behalf of אייל פרחי/Eyal Farchi <[email protected]>
Sent: Sunday, October 7, 2018 2:49 PM
To: [email protected]
Subject: CA SERVER setup and build
Hello I'm new to EPICS. I have success to build basic EPICS application  and read pv value.
I'm using sentOs( Linux), and EPICS 3.16  on 2 machines.  I'm trying to set one machine as server  and one as client and read pv's values   with no success.  Both machines are connected to the
same network  switch.
How  I build ca server and make him readable on the network?
Thanks for your help
CA SERVER setup and build אייל פרחי/Eyal Farchi
Prev: Re: about talking to other record in device support and converting string to int Mark Rivers
Next: perl under Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: CA SERVER setup and build אייל פרחי/Eyal Farchi
ANJ, 08 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
