1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Application Package
To: [email protected]
Date: Tue, 16 Oct 2018 14:14:21 +0200
  Quite interesting discussion, because ESS mentioned several times here.
I am busy these days, so I cannot reply in detail what we are doing here. But if one would like to see what ESS is doing as follows:
  * https://github.com/icshwi/e3          (development)
  * https://github.com/icshwi/e3-builder  (production)
Someday later, if I can, I will present e3 (ESS EPICS environmet) in EPICS collaboration meeting. I hope I could do this in next spring meeting.
If one would like to copy the entire standard epics, I would like to look at the following repo:
  https://github.com/jeonghanlee/epics_builder
  However, it is not for the "production", but for the "personal usage".
  HTH,
  Han
On 10/12/18 8:55 PM, Johnson, Andrew N. wrote:
On 10/12/2018 01:06 PM, Hinko Kocevar wrote:
To avoid hand editing the RELEASE files each time I have an IOC to
build, I've coded a python script that takes a 'recipe' for
base/module/IOC containing some meta data, including top package
dependencies, and delivers a set of built packages - found while
resolving deps at compile time.
There is a tool called Sumo (or EPICS-sumo) that was developed for BESSY
and published by HZB which automates the process of generating RELEASE
files and building dependent modules automatically. It takes a bit of
work to get started with it, but it seems to work very well and I am
proposing this as the basis for the APS Upgrade's IOC builds.
     http://epics-sumo.sourceforge.net/index.html
There are a number of enhancements that could be added by the community
including adding a GUI for easy module configuration changes.
- Andrew
Re: EPICS Application Package Jeong Han Lee
EPICS Application Package Vikram Bhagat via Tech-talk
Re: EPICS Application Package Ralph Lange
Re: EPICS Application Package Bo Jakobsen
RE: EPICS Application Package Hinko Kocevar
Re: EPICS Application Package Johnson, Andrew N.
Prev: Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Next: Weird crash in seq record Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Application Package Johnson, Andrew N.
Next: Re: EPICS Application Package Jeong Han Lee
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
