> It looks like both of them get read into the same data structure, so you might be able to convert the latter into the former by just loading and saving the file - have you tried that?
Yes, I just tried that and it worked!
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Johnson, Andrew N.
Sent: Wednesday, October 17, 2018 11:51 AM
To: [email protected]
Subject: Re: medm color map question
Hi Mark,
On 10/17/2018 11:26 AM, Mark Rivers wrote:
> Most medm adl files I have seen have color map definitions that look
> like this:
> "color map" {
> ncolors=65
> colors {
> ffffff,
> ececec,
> However, some have color maps that look like this:
> "color map" {
> ncolors=65
> dl_color {
> r=255
> g=255
> b=255
> inten=255
> dl_color {
> The adl2edl program does not handle color maps in the second format.
> Can anyone tell me what causes medm to use one format vs the other,
> and is there a way to convert color maps in the second format to be in
> the first format?
The parser inside MEDM implies that the second format using dl_color is an old format as it passes the parsing off to a routine called
parseOldDlColor() while the colors list is parsed by parseDlColor(). It looks like both of them get read into the same data structure, so you might be able to convert the latter into the former by just loading and saving the file - have you tried that?
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
- medm color map question Mark Rivers
- Re: medm color map question Johnson, Andrew N.
RE: Camera Recommendations [SEC=UNCLASSIFIED] Engbretson, Mark S.
<2018>
2025
2026
ADSC Detector use [email protected]
<2018>
2025
2026
