The example is very strange because it actually more or less describes the
problem.
// Because the example acquires and saves 10 images, setting
acquisition
// mode to continuous lets the example finish. If set to
single frame
// or multiframe (at a lower number of images), the example
would just
// hang. This would happen because the example has been
written to
// acquire 10 images while the camera would have been
programmed to
// retrieve less than that.
The example programs works as expected. But that code also is doing cleanup
before the software exits.
If I add a command to grab an image, then the code will not jam, but I then
get
2018/10/17 11:33:00.973 ADSpinnaker::stopCapture exception Spinnaker: Stream
is configured for event driven acquisition. [-1004]
And you can not restart an acquire because the camera is still in steaming
mode.
2018/10/17 11:36:06.969 ADSpinnaker::startCapture exception Spinnaker:
Camera is already streaming [-1004]
2018/10/17 11:36:06.969 2bmbSP1:cam1:Acquire
devAsynInt32::processCallbackOutput process error
2018/10/17 11:36:07.155 ADSpinnaker::startCapture exception Spinnaker:
2018/10/17 11:36:07.155 2bmbSP1:cam1:Acquire
2018/10/17 11:36:07.340 ADSpinnaker::startCapture exception Spinnaker:
2018/10/17 11:36:07.340 2bmbSP1:cam1:Acquire
So the acquire example is actually a bad one.
-----Original Message-----
Sent: Wednesday, October 17, 2018 10:55 AM
To: 'Engbretson, Mark S.' <[email protected]>; [email protected]
Subject: RE: Camera Recommendations [SEC=UNCLASSIFIED]
Mark,
There is a simple example program from Point Grey called
GigEVisionPerformance.cpp that is built as part of ADSpinnaker. It does
continuous acquisition and then calls pCam->EndAcquisition(). Does it work
correctly? If not then you should open a support issue with Point Grey.
Sent: Wednesday, October 17, 2018 9:47 AM
To: Mark Rivers <[email protected]>; [email protected]
There are some issues with the ADSpinnaker software under Ubuntu 18.
Example: I can collect single images fine, I can collect multiple images
fine, but I can not do a continuous scan. Stopping that will stop the
process, but never clears the Acquire PV back to 0. So never cleanly stops,
so can never actually start it back up again.
It looks as if it should be in stopCapture, that is what is being called for
single and multiple, but it does not.
Added trace code as follows -
asynStatus ADSpinnaker::stopCapture()
int status;
static const char *functionName = "stopCapture";
setIntegerParam(ADAcquire, 0);
callParamCallbacks();
setShutter(0);
// Need to wait for the task to set the status to idle
while (1) {
getIntegerParam(ADStatus, &status);
if (status == ADStatusIdle) break;
// if (status == ADStatusIdle) continue;
unlock();
epicsThreadSleep(.1);
lock();
printf(".");
try {
printf("In the start of try block \n");
pCamera_->EndAcquisition();
printf(" after \n");
ImagePtr pImage;
// Need to empty the message queue it could have some images in it
while(pCallbackMsgQ_->tryReceive(&pImage, sizeof(pImage)) != -1) {
printf(".");
printf("At the end of the try block \n");
catch (Spinnaker::Exception &e) {
printf("in the catch block \n");
asynPrint(pasynUserSelf, ASYN_TRACE_ERROR,
"%s::%s exception %s\n",
driverName, functionName, e.what());
return asynError;
printf(" at end of stopAcquire \n");
return asynSuccess;
In the ioc console, I see
epics>
epics> In the start of try block
after
after
.In the start of try block
So I am getting a hang on the statement
Behalf Of Mark Rivers
Sent: Wednesday, October 17, 2018 7:47 AM
To: 'POZAR, Andraz' <[email protected]>; [email protected]
Hi Andraz,
> we have tried using BFLY-PGE-13S2M-CS with adSpinnaker on Ubuntu 16
> and FL3-GE-13S2M-CS with adPontGrey on Centos 7 but both of them "freeze"
after running smoothly for some time.
> They become unresponsive and an IOC reboot is required in some cases
> even
power cycle of the camera.
That's interesting. I have some questions about this:
- What is the approximate mean time it takes for the camera to freeze? I
would like to try to reproduce the problem and want to know how long I would
need to test.
- Have you tried running the Point Grey software, either FlyCap2 or SpinView
with these cameras? Does that also freeze? That would tell us if it is a
problem with the hardware or their library, or the EPICS software.
- Have you tried running the aravisGigE software? That would also help to
see where the problem is.
I own several of the BlackFly GigE cameras, but I am using them for
development, not in production, so I have not run them for a long time where
I might observe this.
However, I am using Point Grey Grasshopper3 cameras in production, both GigE
and USB3 versions. Right now I have a GS3-U3-23S6M that has run for 42 days
at 100 frames/s with no problems. That is running ADPoinyGrey on Centos 7.
I use the same model for tomography with ADPointGrey on Windows where I
typically collect 200GB/day with no issues. I also have 2 GS3-PGE-23S6C
(GigE) cameras that have run for 15 days at 46 frames/s with no problems.
Those are running ADPointGrey on Windows.
Sent: Tuesday, October 16, 2018 5:01 PM
Hi Mark,
Thank you for recommendation, however, we have tried using BFLY-PGE-13S2M-CS
with adSpinnaker on Ubuntu 16 and FL3-GE-13S2M-CS with adPontGrey on Centos
7 but both of them "freeze" after running smoothly for some time. They
become unresponsive and an IOC reboot is required in some cases even power
cycle of the camera. We're running them at toughly 1 Hz so they should get
overworked.
At this stage we're looking at potential alternatives or any kind of advice
if someone has had similar experience with those cameras?
Cheers,
Andraz
Sent: Tuesday, October 16, 2018 10:45 PM
To: POZAR, Andraz <[email protected]>; [email protected]
Subject: Re: Camera Recommendations [SEC=UNCLASSIFIED]
Hi Andraz,
The Point Grey Blackfly cameras will meet your specifications:
https://www.ptgrey.com/blackfly-gige-poe-cameras
Here are 2 examples:
BFLY-PGE-13S2M-CS
1/3 inch, global shutter, 1288x964 pixels
3.75 micron pixels
66% QE, 11 e- read noise, 9339 e- full well
58 dB dynamic range
30 FPS
POE
$345
The following model has significantly better QE, read noise, and dynamic
range in a somewhat larger format:
BFLY-PGE-23S6M-C
1/1.2" sensor, global shutter, 1920x1200 pixels
5.86 micron pixels
80% QE, 7 e- read noise, 33105 e- full well
73 dB dynamic range
41 FPS
POE
$495
Either camera can be used with 3 areaDetector drivers:
ADPointGrey (Windows, Linux RHEL 7 or higher) aravisGigE (Linux, most any
version) ADSpinnaker (Windows, Linux Ubuntu 16 and higher)
behalf of POZAR, Andraz <[email protected]>
Sent: Tuesday, October 16, 2018 12:44 AM
To: [email protected]
Subject: Camera Recommendations [SEC=UNCLASSIFIED]
Hi all,
We're looking into replacing our old Firewire cameras with Ethernet ones and
we'd be interested in any suggestions and experiences you have had with
different camera models.
Some requirements:
- 1/3 inch, global shutter, mono sensor at roughly 1300 x 900
resolution
- Good quantum efficiency and low noise
- Roughly 4 microns pixel size
- Ethernet
- Preferably POE
- areaDetector support
Cheers,
Andraz Pozar
Controls Engineer
Australian Synchrotron
Tel
Email
Web
+61 3 8540 5387
[email protected]<mailto:[email protected]>
www.ansto.gov.au<http://www.ansto.gov.au/>
[fb]<http://www.facebook.com/DiscoverANSTO> [tw] <https://twitter.com/ANSTO>
[ln] <http://www.linkedin.com/company/ansto> [yt]
<http://www.youtube.com/user/ANSTOVideos>
[ansto]
Important: This transmission is intended only for the use of the intended
addressee. It is confidential to the intended addressee and may contain
privileged information and or copyright material. If this email is not
intended for your attention, any use, printing, storage, reproduction or
further disclosure of this communication (including all attachments) is
strictly forbidden. If you have received this transmission in error, please
notify me by telephone or email and immediately delete all copies of this
transmission as well as any attachments.
- Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
- Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
- RE: Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
- RE: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
- RE: Camera Recommendations [SEC=UNCLASSIFIED] Engbretson, Mark S.
RE: medm color map question Mark Rivers
Re: EPICS Application Package Jeong Han Lee
<2018>
2025
2026
<2018>
2025
2026
