1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: BEAST: Show alarms and acknowledge in to 2 different PCs
To: [email protected]
Date: Fri, 19 Oct 2018 11:03:48 +0200
Hello everybody,
I've recently developed an alarm structure for the BEAST Alarm System on CSS and it correctly works; I see all the PVs inserted in the database and I can acknowledge them. The problem is the following:
I have 2 different PCs; in the first one I want to show, in the Alarm Tree Panel and in the Alarm Area Panel, all the PVs belonging to the root, in the other one I want to show only a subgroup of all the PVs belonging to the same root.
How can I do it?
I tried 2 approaches but neither of them work properly:
1-Keeping the same root I can't hide in one PC the PVs I don't want to show.
2-I create 2 different roots, and they points to the same PVs. In this way I select which PVs one root can see and which not. The problem with this configuration is that if I acknowledge one PV in one root, the other root can't see that PV's acknowledge.
After this last approach I also tried to look at the database's construction and I saw that it effectively create 2 PV elements in the database with a different parent, in fact each element can have at most one parent, and thought they receive updates from the same PV status, the acknowledge is done only at database level.
If you have suggestions about a third approach or a correction to one of the previous ones it will be very helpful.
Giovanni
Giovanni Savarese
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Phone: +39 0498068439
email: [email protected]
Prev: Re: CAS / PCAS documentation Johnson, Andrew N.
Next: CSS-BOY combo box - Version 3.2.16 Pilar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ADSC Detector use [email protected]
ANJ, 19 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
