1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS-BOY combo box - Version 3.2.16
Date: Fri, 19 Oct 2018 13:43:37 +0200
Hello everybody,
I have a OPI with some 'Text input' and 'Combo' widgets. After changing the value field and press enter the mouse if focused in the combo widget and it changes it I move the mouse wheel accidentally.
Is there a way of avoiding this behaviour? I was thinking in using the 'show confirm dialog' from the widget properties, but this feature is not implemented in my version for combos.
Thank you very much in advance!
Pilar
http://sevensols.com
Pilar Gil Jaldo
Embedded SW Engineer
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Re: CSS-BOY combo box - Version 3.2.16 Kasemir, Kay via Tech-talk
Prev: BEAST: Show alarms and acknowledge in to 2 different PCs Giovanni Savarese
Next: Re: CSS-BOY combo box - Version 3.2.16 Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
