Ah OK thanks. I'm using a DLS specific 1-6-1 so the problem could be originating from there. I'll take a look at that newer version.
Thanks again, Alan
Sent: 25 October 2018 16:00:18
To: Greer, Alan (OBS,RAL,DIA); [email protected]
Subject: Re: Possible duplicate writeInt32 call when using Asyn
Hi Alan,
What version of the bust module are you using? There were a number of fixes to the busy record logic in R1-7.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, October 25, 2018 9:45 AM
To: [email protected]
Subject: Possible duplicate writeInt32 call when using Asyn
Hello,
I have an IOC with a busy record connected to an asyn parameter within an area detector application. If I perform multiple caputs to the record occasionally I appear to get two writeInt32 calls in quick succession. I'm performing the caput calls from a script to ensure I've eliminated any involvement from a GUI.
Below shows the output from asynTrace when this occurs:
2018/10/25 15:12:52.238 ODN.OD addr 0 queueRequest priority 0 not lockHolder
2018/10/25 15:12:52.238 asynManager::portThread port=ODN.OD callback
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::put<bool>: 1
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::fetch<int>: 0
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::basePut: 'true'
2018/10/25 15:12:52.241 OdinDataDriver:writeInt32: function=100, value=1
2018/10/25 15:12:52.241 EXCALIBUR:OD:Capture devBusyAsyn::interruptCallback pr->val=1, new value=1
2018/10/25 15:12:52.241 EXCALIBUR:OD:Capture devBusyAsyn::processCallback value 1
2018/10/25 15:12:52.241 ODN.OD addr 0 queueRequest priority 0 not lockHolder
2018/10/25 15:12:52.241 asynManager::portThread port=ODN.OD callback
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::put<bool>: 1
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::fetch<int>: 0
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::basePut: 'true'
2018/10/25 15:12:52.245 OdinDataDriver:writeInt32: function=100, value=1
2018/10/25 15:12:52.245 EXCALIBUR:OD:Capture devBusyAsyn::processCallback value 1
This is intermittent and the rate of occurrence is altered by turning on the asynTrace debug.
I'm using
asyn 4-31
ADCore 2-6
EPICS R3.14.12.3
RHEL 6
Is this an issue that anyone has noticed before? I can see that many of our detector application implementations would silently ignore this but in this application we are queueing acquisitions and so we observe in the queue a duplicate request.
Thanks, Alan
- Possible duplicate writeInt32 call when using Asyn [email protected]
- Re: Possible duplicate writeInt32 call when using Asyn Mark Rivers
Re: DM recommedation. J. Lewis Muir
<2018>
2025
2026
calling EIPCS' Raspberry Pi users Chew Eh Piew
<2018>
2025
2026
