Subject: |
Device using undefined record type 'scalcout', place-holder created -> dbdExpand.pl: A different record type named 'scalcout' already exists |
Heinz Junkes <[email protected]> |
To: |
tech Talk EPICS <[email protected]> |
Date: |
Thu, 1 Nov 2018 17:39:35 +0100 |
I have an error message due to scalcout with which I can't start anything.
I also don't know where to look.
calc is the master from https://github.com/epics-modules/calc
I get the following error
epics@kannsein:~/FHI/IOCVACUUM/IOCVACUUMApp/src$ make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
T_A=linux-x86_64 install
make[1]: Entering directory '/home/epics/FHI/IOCVACUUM/IOCVACUUMApp/src/O.linux-x86_64'
Creating dbd file IOCVACUUM.dbd
perl -CSD /home/epics/BASE/epics-base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I/srv/iocs/sys/vacuum/dbd -I/home/epics/SUPPORT/seq-2.2.6/dbd -I/home/epics/SUPPORT/asyn/dbd -I/home/epics/SUPPORT/calc/dbd -I/home/epics/SUPPORT/busy/dbd -I/home/epics/SUPPORT/autosave/dbd -I/home/epics/SUPPORT/iocStats/dbd -I/home/epics/SUPPORT/stream/dbd -I/home/epics/BASE/epics-base/dbd -o IOCVACUUM.dbd base.dbd drvAsynIPPort.dbd asyn.dbd stream.dbd calc.dbd busySupport.dbd devIocStats.dbd asSupport.dbd
Context: recordtype(scalcout) in file '/home/epics/SUPPORT/calc/dbd/sCalcoutRecord.dbd' in file '/home/epics/SUPPORT/calc/dbd/calc.dbd'
while reading 'calc.dbd' to create ‘IOCVACUUM.dbd'
dbdExpand.pl: Exiting due to errors
make[1]: *** No rule to make target '../O.Common/IOCVACUUM.dbd', needed by 'build'. Stop.
make[1]: Leaving directory '/home/epics/FHI/IOCVACUUM/IOCVACUUMApp/src/O.linux-x86_64'
/home/epics/BASE/epics-base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make: *** [install.linux-x86_64] Error 2
make test in calc gives :
.../usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../sCalcPostfix.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../sCalcPerform.c
../sCalcPerform.c: In function ‘sCalcPerform’:
../sCalcPerform.c:1544:7: warning: format not a string literal and no format arguments [-Wformat-security]
sprintf(tmpstr, ps->s);
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../aCalcPostfix.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../aCalcPerform.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../myFreeListLib.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics/SUPPORT/sscan/include -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include -c ../sCalcoutRecord.c
In file included from /home/epics/BASE/epics-base/include/dbAccess.h:19:0,
from ../sCalcoutRecord.c:66:
/home/epics/BASE/epics-base/include/dbBase.h:162:5: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
rset *prset;
Heinz
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
smime.p7s
Description: S/MIME cryptographic signature
- RE: Device using undefined record type 'scalcout', place-holder created -> dbdExpand.pl: A different record type named 'scalcout' already exists Mark Rivers
EPICS Collaboration Meeting Registrations Closing Soon [SEC=UNCLASSIFIED] POZAR, Andraz
<2018>
2025
2026
<2018>
2025
2026
