1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about running CSS from eclipse oxygen
From: "Shroff, Kunal via Tech-talk" <[email protected]>
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 6 Nov 2018 14:56:49 +0000
Hello Zhefu,
The eclipse IDE has always added significant complexity to the cs-studio project. The cs-studio developers have thus decided to move to a new framework called phoebus.
If you are starting fresh, I would strongly recommend starting with cs-studio/phoebus. Currently we have already ported a lot of the application including display builder, databrowser, logbook, alarm, channelfinder,...
To get started you can check out the code and get started
https://github.com/shroffk/phoebus
Cheers,
Kunal
From: [email protected] <[email protected]> on behalf of lzf neu <[email protected]>
Sent: 27 October 2018 07:12:10
To: [email protected]
Subject: Question about running CSS from eclipse oxygen
Hi all,
   I tried to running CSS inside eclipse for RCP developers with version oxygen.3a and I reference the method https://epics.anl.gov/tech-talk/2017/msg01343.php and https://github.com/kasemir/org.csstudio.display.builder
However, I met some problems and the following lines is my steps :
   I download the latest cs-studio-master folder and using "File->Import Maven Existing->Maven Projects" to import cs-studio-master folder as Root directory and use the current IDE and add "plugin-development->Target platform" every plugins (for example: /home/user/eclipse/eclipse-workspace/MyJavaWork/cs-studio-master/applications/alarm/alarm-plugins and etc.) in the cs-studio-master folder. However, there are many errors in the process of building the workplace. I have no idea if I miss some steps.
  I am new in eclipse and struggle in running CSS inside the eclipse for a long time.
  Any help will be appreciate and thanks in advance.
Zhefu
Re: Question about running CSS from eclipse oxygen Kasemir, Kay via Tech-talk
Question about running CSS from eclipse oxygen lzf neu
Prev: Re: record that processes at a given time of day? Michael Westfall via Tech-talk
Next: Re: Question about running CSS from eclipse oxygen Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about running CSS from eclipse oxygen lzf neu
ANJ, 06 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
