1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Current Source / Power supply suggestion
To: Nilson Pereira <[email protected]>, Tech-talk <[email protected]>
Date: Wed, 7 Nov 2018 13:11:49 +0000
Hi Nilson,
We have been very happy with the Sorensen XHR series:
https://www.powerandtest.com/products/dc-bench-power-supplies/xhr-series
We use them for EPICS temperature control using the EPID record, as you are proposing.
These are not digitally programmable, but are controlled by an analog input voltage.  We then use an EPICS D/A converter to control them, and an EPICS thermocouple reader as the PID input.
Recently we have been using the Measurement Computing devices for these.  Here is a photo of a a system consisting of black box with a Measurement Computing device packaged inside that does both thermocouple input and analog output.  The analog output is connected to the Sorensen power supply shown below it.  We are using a model with up to 33 V and 33 A (1000 W) which is well matched to heaters with 1 ohm resistance.  There is a model with maximum 7.5 V output and maximum 130 A, which would be a better match for lower resistance heaters.
[cid:75a8e7bf-3f0c-4b6b-9168-ec47ae64fa4f]
From: [email protected] <[email protected]> on behalf of Nilson Pereira <[email protected]>
Sent: Wednesday, November 7, 2018 6:49 AM
To: Tech-talk
Subject: Current Source / Power supply suggestion
Dear All,
I am developing a temperature control solution based on peltier
elements. The PID loop will control the current on the peltier elements
based on the target temperature.
What I am really looking for are suggestions for remote control linear
DC Current source (0-5A, >300W) or Power supply with available EPICS
drivers.
Any information will be truly appreciated. (Bonus for being easily
available in europe)
Thank you.
Best regards,
Nilson Pereira
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
https://www.helmholtz-berlin.de
Abonnieren Sie unseren monatlichen Newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/>
Subscribe to our monthly newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/index_en.html>
PNG image
Re: Current Source / Power supply suggestion Rod Nussbaumer
Current Source / Power supply suggestion Nilson Pereira
Prev: Current Source / Power supply suggestion Nilson Pereira
Next: Job openings at Diamond Light Source [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Current Source / Power supply suggestion Rod Nussbaumer
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
