1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Current Source / Power supply suggestion
Date: Wed, 7 Nov 2018 13:59:35 +0000
Nilson:
The power supply manufacturers Sorenson, TT, Lambda and other popular
manufacturers have a wide range of power supplies with LAN connections
suitable for control via the EPICS streamDevice support, using a SCPI or
SCPI-like API. These are in wide use at TRIUMF and have been very
successful. If your EPICS support includes some way to drive a DAC via
an analog output record, there are many other supplies that allow
programmable control through an analog input, and supply current and
voltage readback through analog outputs that you can read with ADC
support via analog input records. This mode is also in wide use here.
Rod Nussbaumer
TRIUMF,
Vancouver, Canada.
On 11/07/2018 05:11 AM, Mark Rivers wrote:
> Hi Nilson,
> We have been very happy with the Sorensen XHR series:
> https://www.powerandtest.com/products/dc-bench-power-supplies/xhr-series
> We use them for EPICS temperature control using the EPID record, as you are proposing.
> These are not digitally programmable, but are controlled by an analog input voltage.  We then use an EPICS D/A converter to control them, and an EPICS thermocouple reader as the PID input.
> Recently we have been using the Measurement Computing devices for these.  Here is a photo of a a system consisting of black box with a Measurement Computing device packaged inside that does both thermocouple input and analog output.  The analog output is connected to the Sorensen power supply shown below it.  We are using a model with up to 33 V and 33 A (1000 W) which is well matched to heaters with 1 ohm resistance.  There is a model with maximum 7.5 V output and maximum 130 A, which would be a better match for lower resistance heaters.
> [cid:75a8e7bf-3f0c-4b6b-9168-ec47ae64fa4f]
> Mark
> ________________________________
> From: [email protected] <[email protected]> on behalf of Nilson Pereira <[email protected]>
> Sent: Wednesday, November 7, 2018 6:49 AM
> To: Tech-talk
> Subject: Current Source / Power supply suggestion
> Dear All,
> I am developing a temperature control solution based on peltier
> elements. The PID loop will control the current on the peltier elements
> based on the target temperature.
> What I am really looking for are suggestions for remote control linear
> DC Current source (0-5A, >300W) or Power supply with available EPICS
> drivers.
> Any information will be truly appreciated. (Bonus for being easily
> available in europe)
> Thank you.
> Best regards,
> Nilson Pereira
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> https://www.helmholtz-berlin.de
> Abonnieren Sie unseren monatlichen Newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/>
> Subscribe to our monthly newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/index_en.html>
Current Source / Power supply suggestion Nilson Pereira
Re: Current Source / Power supply suggestion Mark Rivers
Prev: Job openings at Diamond Light Source [email protected]
Next: RE: Current Source / Power supply suggestion Goetze, Kurt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Current Source / Power supply suggestion Mark Rivers
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
