1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: FWD: Record referencing inside device support
Date: Wed, 7 Nov 2018 17:14:41 +0000
Hi Andrew,
In my mind, the C code will be a file containing all the functions to connect, request data stream/polling, run equipment adjustment routines, change properties and close connection. All of this is provided by the manufacturer .so library (which I'm adding to the LIBS target of the IOC's Makefile). So, the IOC will carry everything within itself needed to control the equipment.
What I have in mind is to add this .cpp file to the SRCS target of the IOC's Makefile, and to call all of these functions using subroutine records.
The equipment is an interferometer from SmarAct, called PicoScale.
Best,
Allan S. B. Bugyi.
De: [email protected] <[email protected]> em nome de Johnson, Andrew N. via Tech-talk <[email protected]>
Enviado: quarta-feira, 7 de novembro de 2018 14:54:16
Para: [email protected]
Assunto: Re: Record referencing inside device support
Hi Allan,
On 11/7/18 10:47 AM, Allan Serra Braga Bugyi wrote:
> I have the need to access the record support structs inside my C code.
> What I want is to be able to access the records' fields to pass them as
> parameters to some functions. These functions are inside a dynamic
> library .so from the manufacturer. Any idea or workaround?
What is "your C code" — where is it running and what calls it? You need
to describe what you're doing it a bit more detail for us to be able to
help you as the answers will be different for different circumstances...
- Andrew
RE: Record referencing inside device support Mark Rivers
Record referencing inside device support Allan Serra Braga Bugyi
Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
Prev: Re: Record referencing inside device support Allan Serra Braga Bugyi
Next: Re: Record referencing inside device support Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
Next: RE: Record referencing inside device support Mark Rivers
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
