Hi Allan,
If you look at some existing device-support code (for example, base-3.15.4/src/std/dev/devAaoSoft.c) you'll see that routines in that file are called with a pointer to the record struct. You might want
to look at this presentation from a recent EPICS class:
https://epics.anl.gov/docs/APS2015/01-EPICS-Device-Support.pdf
epics.anl.gov
APS EPICS Training • 2015-01-08 • Writing Device Support 2 Writing Device Support – Scope An overview of the concepts associated with writing EPICS Device Support routines.
Tim Mooney ( [email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, November 7, 2018 11:10:54 AM
To: Mooney, Tim M.; [email protected]
Subject: Re: Record referencing inside device support
Hi Tim,
My limited comprehension of EPICS building facility may be blurring my understanding of the problem. In my comprehension, EPICS building facility generates header files from .db files, right? So, each record will be
an "instance" of the accordingly struct. However, this happens during compilation time. Where would it be possible to know the structs' names for referencing inside device support?
Best ,
Allan S. B. Bugyi
Technology Development Analyst
[email protected]
(+55 19) 3512-3520
SOL/Beamline Software Group
Brazilian Synchrotron Light
Laboratory (LNLS)
Center of Research in Energy and Materials (CNPEM)
http://lnls.cnpem.br
De: Mooney, Tim M. <[email protected]>
Enviado: quarta-feira, 7 de novembro de 2018 14:53:19
Para: Allan Serra Braga Bugyi; [email protected]
Assunto: Re: Record referencing inside device support
Hi Allan,
My first thought would be to write device support for the record. Device support has access to the record structure.
Hello all,
I have the need to access the record support structs inside my C code. What I want is to be able to access the records' fields to pass them as parameters to some functions. These functions are inside a dynamic library
.so from the manufacturer. Any idea or workaround?
Many thanks!
Allan S. B. Bugyi
[email protected]
(+55 19) 3512-3520
Laboratory (LNLS)
- Record referencing inside device support Allan Serra Braga Bugyi
- Re: Record referencing inside device support Mooney, Tim M. via Tech-talk
- Re: Record referencing inside device support Allan Serra Braga Bugyi
FWD: Record referencing inside device support Allan Serra Braga Bugyi
Re: Current Source / Power supply suggestion David Vine
<2018>
2025
2026
Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
<2018>
2025
2026
ANJ, 07 Nov 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
