Dear Nilson, I have been using peltier drivers from Meerstetter (https://www.meerstetter.ch/shop/tec-controllers/tec-1122-detail) and have been very happy with their performance. An EPICS driver is available here: https://github.com/djvine/TEC1122 Best, David > To: Tech-talk > Subject: Current Source / Power supply suggestion > > Dear All, > > I am developing a temperature control solution based on peltier > elements. The PID loop will control the current on the peltier elements > based on the target temperature. > > What I am really looking for are suggestions for remote control linear > DC Current source (0-5A, >300W) or Power supply with available EPICS > drivers. > > Any information will be truly appreciated. (Bonus for being easily > available in europe) > > Thank you. > > Best regards, > > Nilson Pereira Best regards, David Vine (925) 326 7503
This e-mail and any attachments are provided for the sole use of the intended recipient(s), and may contain information that is confidential, privileged, proprietary or otherwise protected by law. If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy, forward or otherwise disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and delete the original message from your mail system. Thank you.
| ANJ, 07 Nov 2018 |
Home
News
About
Talk
Base
Modules
Extensions
