1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ?
From: "Giacomo S. via Tech-talk" <[email protected]>
Date: Thu, 29 Nov 2018 10:44:31 +0100
Hello everyone.
In epics 3.16 I see a couple of .pc files are generated and installed:
./lib/pkgconfig/epics-base-linux-x86_64.pc
./lib/pkgconfig/epics-base.pc
Nonetheless, when using pkgconfig to build/link against Epics, needed  -lca -ldbCore -lCom  are missing from the command line.
Looking at the "Libs:" line at the bottom of epics-base-linux-x86_64.pc, I see they are actually missing. I added them manually and the build works.
Am I missing something or is it a bug?
Thanks.
Giacomo, Elettra Synchrotron Radiation Facility, Trieste, Italy.
A portion of the .pc file follows:
EPICS_BASE_IOC_LIBS=dbRecStd dbCore ca Com
# Directories
includedir_osi=${prefix}/include
includedir_osd=${prefix}/include/os/Linux
includedir_comp=${prefix}/include/compiler/gcc
includedirs=${includedir_osi} ${includedir_osd} ${includedir_comp}
dbddir=${prefix}/dbd
dbdir=${prefix}/db
# Tool chain
CC=/usr/bin/gcc
CXX=/usr/bin/g++
CPP=/usr/bin/gcc -x c -E
AR=/usr/bin/ar -rc
LD=/usr/bin/ld -r
Version: 3.16.2.0
Description: EPICS Base for linux-x86_64
Cflags: -I${includedir_osi} -I${includedir_osd} -I${includedir_comp} -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -D_X86_64_ -DUNIX -Dlinux -mtune=generic -m64
Libs: -L${libdir} -rdynamic -m64
Libs.private: -lpthread -lreadline -lm -lrt -ldl -lgcc
Re: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ? Michael Davidsaver via Tech-talk
Prev: Problems with using PI E-712 controller 孙天啸 via Tech-talk
Next: streamdevice I/O Intr William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with using PI E-712 controller Mark Rivers via Tech-talk
Next: Re: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ? Michael Davidsaver via Tech-talk
ANJ, 29 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
