1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems with using PI E-712 controller
Date: Thu, 29 Nov 2018 08:41:54 +0000
    I used the PIGCS2Src in motor-6-8 to drive the PI E712 piezomotor controller.
    But there are two error messages as starting up
1.PIasynController: unknown controller type e712
2.writeFloat64() GCS controller not initialized!
 And the detail of the startup message is following:
#!../../bin/linux-x86_64/e712
## You may have to change e712 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioce712")
epicsEnvSet("TOP","/home/suntianxiao/PIE-712")
epicsEnvSet("SUPPORT","/BLC/epics/synApps_5_7/support")
epicsEnvSet("MOTOR","/BLC/epics/synApps_5_7/support/motor-6-8")
epicsEnvSet("ASYN","/BLC/epics/synApps_5_7/support/asyn-4-21")
epicsEnvSet("CALC","/BLC/epics/synApps_5_7/support/calc-3-2")
epicsEnvSet("EPICS_BASE","/BLC/epics/base")
cd "/home/suntianxiao/PIE-712"
dbLoadDatabase "dbd/e712.dbd"
e712_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadRecords("db/xxx.db","user=suntianxiaoHost")
dbLoadTemplate "/home/suntianxiao/PIE-712/iocBoot/ioce712/motor.substitutions"
drvAsynIPPortConfigure("e712","172.16.0.35:50000",0,0,0)
#asynOctetSetInputEos("e712",0,"\n")
#asynOctetSetOutputEos("e712",0,"\n")
#asynSetTraceMask("e712",0,1)
#asynSetTraceIOMask("e712",0,1)
PI_GCS2_CreateController("PIE712_1","e712",4,0,0,100,1000)
2018/11/29 16:06:48.453 read from e712: (c)2015 Physik Instrumente (PI) GmbH & Co. KG, E-712, 117071883, 14.00.12.00
2018/11/29 16:06:48.453 PIasynController: unknown controller type e712: (C)2015 PHYSIK INSTRUMENTE (PI) GMBH & CO. KG, E-712, 117071883, 14.00.12.00
cd "/home/suntianxiao/PIE-712/iocBoot/ioce712"
iocInit
Starting iocInit
## EPICS R3.14.12.6
## EPICS Base built Nov 27 2018
2018/11/29 16:06:48.454 IOC:m1 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 IOC:m2 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 IOC:m3 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 PIasynController::writeFloat64() GCS controller not initialized!
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m1 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m2 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m3 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 IOC:m4 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 PIasynController::writeFloat64() GCS controller not initialized!
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m4 pasyn{Float64,Int32}->write returned
## Start any sequence programs
#seq sncxxx,"user=suntianxiaoHost"
epics> dbl
IOC:m1
IOC:m2
IOC:m3
IOC:m4
epics> ^C
Are there any mistakes in my st.cmd writing?
Tian-xiao Sun
SSRF
Prev: Re: Question about this mailing list Ralph Lange via Tech-talk
Next: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ? Giacomo S. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about this mailing list Johnson, Andrew N. via Tech-talk
Next: Fw: Problems with using PI E-712 controller Mark Rivers via Tech-talk
ANJ, 29 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
