1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Problems with using PI E-712 controller
Date: Thu, 29 Nov 2018 12:31:45 +0000
Forwarding because Reply All doesn't work and I forgot to add tech-talk.  Grrrr.
Sent: Thursday, November 29, 2018 6:09 AM
To: 孙天啸
Subject: Re: Problems with using PI E-712 controller
> 2018/11/29 16:06:48.453 PIasynController: unknown controller type e712: (C)2015 PHYSIK INSTRUMENTE (PI) GMBH & CO. KG, E-712, 117071883, 14.00.12.00
The error message you are seeing is misleading, due to an error in PIasynController.cpp.  It contains these lines:
m_pGCSController = PIGCSController::CreateGCSController(pInterface, inputBuff);
if (NULL == m_pGCSController)
asynPrint(pAsynCom, ASYN_TRACE_ERROR|ASYN_TRACE_FLOW,
  "PIasynController: unknown controller type %s: %s\n",
  asynPort, inputBuff);
return;
So it is reporting the asynPort as the controller type, not the actual controller type.  But this error means that PIGCSController::CreateGCSController failed and returned null.  This is that code:
 *  create instance of GCS controller depending on identification (\a szIDN)
PIGCSController* PIGCSController::CreateGCSController(PIInterface* pInterface, const char* szIDN)
if ( strstr(szIDN, "C-663") != NULL
|| strstr(szIDN, "C-863") != NULL
|| strstr(szIDN, "C-867") != NULL
|| strstr(szIDN, "C-884") != NULL
|| strstr(szIDN, "E-861") != NULL
|| strstr(szIDN, "E-871") != NULL
|| strstr(szIDN, "E-873") != NULL
return new PIGCSMotorController(pInterface, szIDN);
else if ( strstr(szIDN, "E-517") != NULL)
return new PIE517Controller(pInterface, szIDN);
else if ( strstr(szIDN, "E-753") != NULL
|| strstr(szIDN, "E-709") != NULL
|| strstr(szIDN, "E-712") != NULL
|| strstr(szIDN, "E-725") != NULL
|| strstr(szIDN, "E-727") != NULL
return new PIGCSPiezoController(pInterface, szIDN);
else if ( strstr(szIDN, "E-755") != NULL)
return new PIE755Controller(pInterface, szIDN);
else if ( strstr(szIDN, "C-702") != NULL)
return new PIC702Controller(pInterface, szIDN);
else if ( strstr(szIDN, "HEXAPOD") != NULL
|| strstr(szIDN, "F-HEX") != NULL
|| strstr(szIDN, "F-206") != NULL
|| strstr(szIDN, "M-8") != NULL
|| strstr(szIDN, "C-887") != NULL
if (IsGCS2(pInterface))
return new PIGCS2_HexapodController(pInterface, szIDN);
else
return new PIHexapodController(pInterface, szIDN);
else
return NULL;
Note that the szIDN string error message you see does include the string E-712 so it should have returned:
For some reason that is failing.  You will need to debug to figure out why, I can't spot the problem.  The constructors for PIGCSPiezoController and its base class are very simple, and do not throw exceptions that I can see.
From: [email protected] <[email protected]> on behalf of 孙天啸 via Tech-talk <[email protected]>
Sent: Thursday, November 29, 2018 2:41 AM
To: [email protected]
Subject: Problems with using PI E-712 controller
    I used the PIGCS2Src in motor-6-8 to drive the PI E712 piezomotor controller.
    But there are two error messages as starting up
1.PIasynController: unknown controller type e712
2.writeFloat64() GCS controller not initialized!
 And the detail of the startup message is following:
#!../../bin/linux-x86_64/e712
## You may have to change e712 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioce712")
epicsEnvSet("TOP","/home/suntianxiao/PIE-712")
epicsEnvSet("SUPPORT","/BLC/epics/synApps_5_7/support")
epicsEnvSet("MOTOR","/BLC/epics/synApps_5_7/support/motor-6-8")
epicsEnvSet("ASYN","/BLC/epics/synApps_5_7/support/asyn-4-21")
epicsEnvSet("CALC","/BLC/epics/synApps_5_7/support/calc-3-2")
epicsEnvSet("EPICS_BASE","/BLC/epics/base")
cd "/home/suntianxiao/PIE-712"
dbLoadDatabase "dbd/e712.dbd"
e712_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadRecords("db/xxx.db","user=suntianxiaoHost")
dbLoadTemplate "/home/suntianxiao/PIE-712/iocBoot/ioce712/motor.substitutions"
drvAsynIPPortConfigure("e712","172.16.0.35:50000",0,0,0)
#asynOctetSetInputEos("e712",0,"\n")
#asynOctetSetOutputEos("e712",0,"\n")
#asynSetTraceMask("e712",0,1)
#asynSetTraceIOMask("e712",0,1)
PI_GCS2_CreateController("PIE712_1","e712",4,0,0,100,1000)
2018/11/29 16:06:48.453 read from e712: (c)2015 Physik Instrumente (PI) GmbH & Co. KG, E-712, 117071883, 14.00.12.00
cd "/home/suntianxiao/PIE-712/iocBoot/ioce712"
iocInit
Starting iocInit
## EPICS R3.14.12.6
## EPICS Base built Nov 27 2018
2018/11/29 16:06:48.454 IOC:m1 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 IOC:m2 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 IOC:m3 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 PIasynController::writeFloat64() GCS controller not initialized!
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m1 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m2 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m3 pasyn{Float64,Int32}->write returned
2018/11/29 16:06:48.454 IOC:m4 devMotorAsyn.c::init_record: pasynGenericPointer->read returned 2018/11/29 16:06:48.454 PIasynController::writeFloat64() GCS controller not initialized!
2018/11/29 16:06:48.454 devMotorAsyn::asynCallback: IOC:m4 pasyn{Float64,Int32}->write returned
## Start any sequence programs
#seq sncxxx,"user=suntianxiaoHost"
epics> dbl
IOC:m1
IOC:m2
IOC:m3
IOC:m4
epics> ^C
Are there any mistakes in my st.cmd writing?
Tian-xiao Sun
SSRF
Re: Problems with using PI E-712 controller Allan Serra Braga Bugyi via Tech-talk
Problems with using PI E-712 controller 孙天啸 via Tech-talk
Prev: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Next: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems with using PI E-712 controller 孙天啸 via Tech-talk
Next: Re: Problems with using PI E-712 controller Allan Serra Braga Bugyi via Tech-talk
ANJ, 29 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
