1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice I/O Intr
From: Dirk Zimoch via Tech-talk <[email protected]>
To: <[email protected]>
Date: Thu, 29 Nov 2018 13:37:31 +0100
Hi William,
Have you tried to give the output record a high priority?
Dirk
On 29.11.2018 13:27, William Kirstaedter via Tech-talk wrote:
I'm sorry to send this again but my first mail got soft-rejected because I wasnt a subscriber.
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 29.11.2018 um 11:34 schrieb William Kirstaedter:
I have a small problem with a fast Device, maybe somebody already had this problem and can help out? :)
It runs via I/O Intr.
I am able to start the reporting, but I cant stop it. It seems that the stop command doesnt get through.... could it be that somehow the communication is blocked by the fast input? how could I fix that?
Its really simple to control:
You send "STM\r", it starts reporting every 18ms "tmp,<float>,<float>\r"
You send "ETM\r", it stops doing that, terminating communication with "txx\r".
all ASCII formatted.
my records:
tc.db file:
record(bo, "$(P):$(R):Toggle"){
   field(DESC, "Toggle Reading")
   field(DTYP, "stream")
   field(OUT, "@tc.proto toggle $(BUS)")
   field(ZNAM, "ETM")
   field(ONAM, "STM")
   field(VAL, "0")
record(ai, "$(P):$(R):Temperature") {
  field(DESC, "Temperature")
  field (DTYP, "stream")
  field (INP, "@tc.proto read_K $(BUS)")
  field (SCAN, "I/O Intr")
  field(EGU, "K")
record(ai, "$(P):$(R):ThermoVoltage"){
  field(DESC, "TC Thermovoltage")
  field(INP, "@tc.proto read_nV $(BUS)")
  field(SCAN, "I/O Intr")
  field(EGU, "nV")
tc.proto file:
Terminator = CR;
ExtraInput = Ignore;
toggle {
        out "%{ETM|STM}";
        in "txx";
read_K {
        in "tmp,%f,%*f";
read_nV {
        in "tmp,%*f,%f";
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Prev: Fw: Problems with using PI E-712 controller Mark Rivers via Tech-talk
Next: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
ANJ, 29 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
