How are you commanding the bo record? Are you sure its value is being commanded to zero when you want to stop reading?
Did you try something like, 'caput xxx:Toggle 0' ?
On Thu, Nov 29, 2018 at 10:21 AM William Kirstaedter via Tech-talk < [email protected]> wrote: Hi Dirk,
thanks for the quick answer.
I have set
field(PRIO, "HIGH")
but this doesnt seem to do anything?
I have asynTraceMask on aswell but I dont see the "ETM" command ever
pass through...
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 29.11.2018 um 13:37 schrieb Dirk Zimoch via Tech-talk:
> Hi William,
> Have you tried to give the output record a high priority?
> Dirk
> On 29.11.2018 13:27, William Kirstaedter via Tech-talk wrote:
>> I'm sorry to send this again but my first mail got soft-rejected
>> because I wasnt a subscriber.
>> Faradayweg 4-6
>> 14195 Berlin
>> Tel: 030 8413 5405
>> Am 29.11.2018 um 11:34 schrieb William Kirstaedter:
>>> Hi,
>>> I have a small problem with a fast Device, maybe somebody already
>>> had this problem and can help out? :)
>>> It runs via I/O Intr.
>>> I am able to start the reporting, but I cant stop it. It seems that
>>> the stop command doesnt get through....
>>> could it be that somehow the communication is blocked by the fast
>>> input? how could I fix that?
>>> Its really simple to control:
>>> You send "STM\r", it starts reporting every 18ms
>>> "tmp,<float>,<float>\r"
>>> You send "ETM\r", it stops doing that, terminating communication
>>> with "txx\r".
>>> all ASCII formatted.
>>> my records:
>>> tc.db file:
>>> record(bo, "$(P):$(R):Toggle"){
>>> field(DESC, "Toggle Reading")
>>> field(DTYP, "stream")
>>> field(OUT, "@tc.proto toggle $(BUS)")
>>> field(ZNAM, "ETM")
>>> field(ONAM, "STM")
>>> field(VAL, "0")
>>> record(ai, "$(P):$(R):Temperature") {
>>> field(DESC, "Temperature")
>>> field (DTYP, "stream")
>>> field (INP, "@tc.proto read_K $(BUS)")
>>> field (SCAN, "I/O Intr")
>>> field(EGU, "K")
>>> record(ai, "$(P):$(R):ThermoVoltage"){
>>> field(DESC, "TC Thermovoltage")
>>> field(INP, "@tc.proto read_nV $(BUS)")
>>> field(SCAN, "I/O Intr")
>>> field(EGU, "nV")
>>> tc.proto file:
>>> Terminator = CR;
>>> ExtraInput = Ignore;
>>> toggle {
>>> out "%{ETM|STM}";
>>> in "txx";
>>> read_K {
>>> in "tmp,%f,%*f";
>>> read_nV {
>>> in "tmp,%*f,%f";
>> Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
>> Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
>> [General Data Protection Regulation (GDPR)] der Europaeischen Union.
Mike Westfall
Control Systems Software Engineer
- Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
- Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Re: Problems with using PI E-712 controller Mark Rivers via Tech-talk
Re: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ? Michael Davidsaver via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
ANJ, 29 Nov 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
