Hi Douglas,
> So, i intend to implement this function inside the
> asynPortDriver readFloat64, as at the tutorial measCompTutorial, and to
> create a ai input record with SCAN=I/0 Intr.
> But now is my doubt, when (and how) this readFloat64 is call?
If you implement reading the temperature in readFloat64 then it will only work with records that are periodically scanned (SCAN=1 second, etc.).
If you want the record to work with SCAN=I/O Intr then you need to read the temperature inside a polling loop in your driver. This lets you update much faster than the normal periodic SCAN rates.
There is an example of doing that for digital inputs on page 41 in the tutorial.
https://github.com/epics-modules/measComp/blob/master/documentation/measCompTutorial.pdf
?You would just need to change that to read your temperature, and call setDoubleParam rather than setUIntDigitalParam.
If you write the poller then periodically scanned records will still work, without your driver needing to implement the readFloat64() function. The reason is that your poller has put the latest value in the parameter library, and the asynPortDriver::readFloat64() base-class function will return the current value from the parameter library.
From: [email protected] <[email protected]> on behalf of Douglas Henrique C. de Araújo via Tech-talk <[email protected]>
Sent: Tuesday, December 4, 2018 6:44 AM
To: [email protected]
Subject: Asyn PortDriver readFloat64
Dear all,
I am developing a driver for a equipment using asynPortDriver, and I
need a record temperatureActual_RBV that call a function of a dynamic
library that ask to detector the actual temperature and the detector
return the value. So, i intend to implement this function inside the
Thank you.
Best regards
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron - (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br<http://www.lnls.br>
- Re: Asyn PortDriver readFloat64 Douglas Henrique C. de Araújo via Tech-talk
- Asyn PortDriver readFloat64 Douglas Henrique C. de Araújo via Tech-talk
RE: asynDriver - UDP server Joao Afonso via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
