Hej,
You can have a look here:
(Which packets to install)
https://github.com/jeonghanlee/pkg_automation/blob/master/pkg_automation.bash
Or here:
https://github.com/jeonghanlee/extensions.git
Or here:
https://github.com/EuropeanSpallationSource/extensions/tree/paths_for_Debian
In other words, I think it makes sense to have a script, which does install
all packages needed, and then you may need to patch the Makefile
(or any better integration of this patch, needed for Debian 9 at least):
cat patches/Xp_is_not_needed.p0.patch
diff --git medm/Makefile medm/Makefile
index 007ec46..3950a2c 100644
--- medm/Makefile
+++ medm/Makefile
@@ -170,7 +170,7 @@ USR_LIBS_solaris = Xm12 Xt Xmu X11 Xext
Xm12_DIR = $(MOTIF_LIB)
endif
-USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
+USR_LIBS_Linux = Xm Xt Xmu X11 Xext
#Xp is not available and not needed on Linux Mint 18
#USR_LIBS_Linux = Xm Xt Xmu X11 Xext
Andrew,
Would it make sense to have a ./configure script in extensions/ ?
I may be able to provide a pacth & pull request some day..
On 07/12/18 10:00, Florian Feldbauer via Tech-talk wrote:
Hey Andrew,
I'm not using MEDM but libXt-dev is not listed for Ubuntu on the webpage. Maybe
it is a dependency of one of the other packages?
I just checked which package contains libXt.so and found libXt-dev.
Usually the lib packages contain libXXX.so.VERSION and the corresponding
development packages contain the libXXX.so and libXXX.a files.
If the linker doesn't find the shared object it tries the static one. I guess
that's why the error message quotes
> *** No rule to make target `/usr/lib64/libXt.a', needed by `medm'.
Cheers,
Florian
Am 06.12.2018 um 18:26 schrieb Johnson, Andrew N.:
Hi Florian,
Is this in addition to the list of packages given on the MEDM web-page
<https://epics.anl.gov/extensions/medm/index.php> ? That does mention Ubuntu
14.04 which is what I was testing against when I added that list.
Strictly speaking the build says it's looking for libXt.a but it should be
happy with a copy of libXt.so instead, unless you have configured the build
for static linking.
- Andrew
On 12/6/18 4:55 AM, Florian Feldbauer via Tech-talk wrote:
Hey,
at least under debian, you need to install the package libxt-dev.
Guess it's the same under Ubuntu.
Hope this helps!
Cheers,
Florian
On 12/6/18 11:33 AM, nieyg--- via Tech-talk wrote:
I just tried to build medm using epics base-3.14.12.5 on Ubuntu 14.04. It
gives an error:
I suspect a configuration error. Any suggestions?
Thanks
[email protected]
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Fach-Nr. 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
- Re: medm build Jeong Han Lee via Tech-talk
- medm build nieyg--- via Tech-talk
- Re: medm build Florian Feldbauer via Tech-talk
- Re: medm build Johnson, Andrew N. via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
