1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm build
From: Jeong Han Lee via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 7 Dec 2018 10:33:12 +0100
There are few more interesting cases which I've found so far :
1) EPICS Base version
2) Linux Distribution (Debian, CentOS)
The following README may help your case.
https://github.com/jeonghanlee/extensions/blob/master/README.md
HTH,
Han
On 12/7/18 10:26 AM, Torsten Bögershausen via Tech-talk wrote:
Hej,
You can have a look here:
(Which packets to install)
https://github.com/jeonghanlee/pkg_automation/blob/master/pkg_automation.bash
Or here:
   https://github.com/jeonghanlee/extensions.git
Or here:
https://github.com/EuropeanSpallationSource/extensions/tree/paths_for_Debian
In other words, I think it makes sense to have a script, which does install
all packages needed, and then you may need to patch the Makefile
(or any better integration of this patch, needed for Debian 9 at least):
cat patches/Xp_is_not_needed.p0.patch
diff --git medm/Makefile medm/Makefile
index 007ec46..3950a2c 100644
--- medm/Makefile
+++ medm/Makefile
@@ -170,7 +170,7 @@ USR_LIBS_solaris = Xm12 Xt Xmu X11 Xext
  Xm12_DIR = $(MOTIF_LIB)
  endif
-USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
+USR_LIBS_Linux = Xm Xt Xmu X11 Xext
  #Xp is not available and not needed on Linux Mint 18
  #USR_LIBS_Linux = Xm Xt Xmu X11 Xext
Andrew,
Would it make sense to have a ./configure script in extensions/ ?
I may be able to provide a pacth & pull request some day..
On 07/12/18 10:00, Florian Feldbauer via Tech-talk wrote:
Hey Andrew,
I'm not using MEDM but libXt-dev is not listed for Ubuntu on the webpage. Maybe it is a dependency of one of the other packages?
I just checked which package contains libXt.so and found libXt-dev.
Usually the lib packages contain libXXX.so.VERSION and the corresponding development packages contain the libXXX.so and libXXX.a files.
If the linker doesn't find the shared object it tries the static one. I guess that's why the error message quotes
 > *** No rule to make target `/usr/lib64/libXt.a', needed by `medm'.
Cheers,
Florian
Am 06.12.2018 um 18:26 schrieb Johnson, Andrew N.:
Hi Florian,
Is this in addition to the list of packages given on the MEDM web-page <https://epics.anl.gov/extensions/medm/index.php> ? That does mention Ubuntu 14.04 which is what I was testing against when I added that list.
Strictly speaking the build says it's looking for libXt.a but it should be happy with a copy of libXt.so instead, unless you have configured the build for static linking.
- Andrew
On 12/6/18 4:55 AM, Florian Feldbauer via Tech-talk wrote:
Hey,
at least under debian, you need to install the package libxt-dev.
Guess it's the same under Ubuntu.
Hope this helps!
Cheers,
Florian
On 12/6/18 11:33 AM, nieyg--- via Tech-talk wrote:
I just tried to build medm using epics base-3.14.12.5 on Ubuntu 14.04. It gives an error:
I suspect a configuration error. Any suggestions?
Thanks
[email protected]
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Fach-Nr. 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
Re: medm build Ralph Lange via Tech-talk
RE: medm build Heesterman, Peter J via Tech-talk
medm build nieyg--- via Tech-talk
Re: medm build Florian Feldbauer via Tech-talk
Re: medm build Johnson, Andrew N. via Tech-talk
Re: medm build Torsten Bögershausen via Tech-talk
Prev: Re: medm build Torsten Bögershausen via Tech-talk
Next: Re: medm build Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
