Hi Han, et. al.,
I have been able to build and use medm on Ubuntu 18.04.
I needed to install these dependencies, and I have LibXt.a in /usr/lib/x86_64-linux-gnu:
build-essential
libmotif-dev
libxmu-dev
I have also (unsuccessfully) attempted to build it on Scientific Linux 7 by adding these dependencies:
openmotif
libXmu
libXt
libXm.so.4
I end up with build fail because libXt.a is unavailable, but I do have libXt.so in /usr/lib64.
Hope this helps,
Peter.
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Jeong Han Lee via Tech-talk
Sent: 07 December 2018 09:33
To: [email protected]
Subject: Re: medm build
There are few more interesting cases which I've found so far :
1) EPICS Base version
2) Linux Distribution (Debian, CentOS)
The following README may help your case.
https://github.com/jeonghanlee/extensions/blob/master/README.md
HTH,
Han
On 12/7/18 10:26 AM, Torsten Bögershausen via Tech-talk wrote:
> Hej,
> You can have a look here:
> (Which packets to install)
> https://github.com/jeonghanlee/pkg_automation/blob/master/pkg_automati
> on.bash
> Or here:
> https://github.com/jeonghanlee/extensions.git
> Or here:
> https://github.com/EuropeanSpallationSource/extensions/tree/paths_for_
> Debian
> In other words, I think it makes sense to have a script, which does
> install all packages needed, and then you may need to patch the
> Makefile (or any better integration of this patch, needed for Debian 9 at least):
> cat patches/Xp_is_not_needed.p0.patch
> diff --git medm/Makefile medm/Makefile index 007ec46..3950a2c 100644
> --- medm/Makefile
> +++ medm/Makefile
> @@ -170,7 +170,7 @@ USR_LIBS_solaris = Xm12 Xt Xmu X11 Xext
> Xm12_DIR = $(MOTIF_LIB)
> endif
> -USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
> +USR_LIBS_Linux = Xm Xt Xmu X11 Xext
> #Xp is not available and not needed on Linux Mint 18
> #USR_LIBS_Linux = Xm Xt Xmu X11 Xext
> Andrew,
> Would it make sense to have a ./configure script in extensions/ ?
> I may be able to provide a pacth & pull request some day..
> On 07/12/18 10:00, Florian Feldbauer via Tech-talk wrote:
>> Hey Andrew,
>> I'm not using MEDM but libXt-dev is not listed for Ubuntu on the
>> webpage. Maybe it is a dependency of one of the other packages?
>> I just checked which package contains libXt.so and found libXt-dev.
>> Usually the lib packages contain libXXX.so.VERSION and the
>> corresponding development packages contain the libXXX.so and libXXX.a
>> files.
>> If the linker doesn't find the shared object it tries the static one.
>> I guess that's why the error message quotes
>> > *** No rule to make target `/usr/lib64/libXt.a', needed by `medm'.
>> Cheers,
>> Florian
>> Am 06.12.2018 um 18:26 schrieb Johnson, Andrew N.:
>>> Hi Florian,
>>> Is this in addition to the list of packages given on the MEDM
>>> web-page <https://epics.anl.gov/extensions/medm/index.php> ? That
>>> does mention Ubuntu 14.04 which is what I was testing against when I
>>> added that list.
>>> Strictly speaking the build says it's looking for libXt.a but it
>>> should be happy with a copy of libXt.so instead, unless you have
>>> configured the build for static linking.
>>> - Andrew
>>> On 12/6/18 4:55 AM, Florian Feldbauer via Tech-talk wrote:
>>>> Hey,
>>>> at least under debian, you need to install the package libxt-dev.
>>>> Guess it's the same under Ubuntu.
>>>> Hope this helps!
>>>> Cheers,
>>>> Florian
>>>> On 12/6/18 11:33 AM, nieyg--- via Tech-talk wrote:
>>>>> I just tried to build medm using epics base-3.14.12.5 on Ubuntu
>>>>> 14.04. It gives an error:
>>>>> I suspect a configuration error. Any suggestions?
>>>>> Thanks
>>>>> [email protected]
>>>> Dr. Florian Feldbauer
>>>> Ruhr-Universität Bochum
>>>> Experimentalphysik I AG
>>>> Fach-Nr. 125
>>>> Universitätsstr. 150
>>>> D-44801 Bochum
>>>> Office: NB 2/134
>>>> Phone: (+49)234 / 32-23563
>>>> Fax: (+49)234 / 32-14170
>>> Arguing for surveillance because you have nothing to hide is no
>>> different than making the claim, "I don't care about freedom of
>>> speech because I have nothing to say." -- Edward Snowdon
- medm build nieyg--- via Tech-talk
- Re: medm build Florian Feldbauer via Tech-talk
- Re: medm build Johnson, Andrew N. via Tech-talk
- Re: medm build Torsten Bögershausen via Tech-talk
- Re: medm build Jeong Han Lee via Tech-talk
Re: medm build Ralph Lange via Tech-talk
Re: medm build Michael Davidsaver via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
