1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Makefile question
Date: Sun, 9 Dec 2018 13:49:36 +0000
I have a Makefile that builds 2 libraries.  Library A must be built before library B, because B depends on A (important for dynamic builds on Windows).  What is the rule I need to add to force A to be built before B?
This is the actual Makefile.  bitshuffle_hdf5.lib must be built after bitshuffle.lib.
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
ifeq ($(WITH_BITSHUFFLE),YES)
  ifeq ($(BITSHUFFLE_EXTERNAL),NO)
    LIBRARY_IOC = bitshuffle
    BITSHUFFLE = $(TOP)/supportApp/bitshuffleSrc
    USR_CFLAGS_Linux += -std=c99
    USR_CFLAGS_WIN32 += -DLZ4_DLL_EXPORT=1
    INC += bitshuffle.h
    INC += bitshuffle_core.h
    INC += bshuf_h5filter.h
    bitshuffle_SRCS += bitshuffle.c
    bitshuffle_SRCS += bitshuffle_core.c
    bitshuffle_SRCS += iochain.c
    SRC_DIRS += $(BITSHUFFLE)/lz4
    INC += lz4.h
    bitshuffle_SRCS += lz4.c
    ifeq ($(WITH_HDF5),YES)
        LIBRARY_IOC = bitshuffle_hdf5
        bitshuffle_hdf5_SRCS += bshuf_h5filter.c
        bitshuffle_hdf5_SRCS += bshuf_h5plugin.c
        bitshuffle_hdf5_LIBS += bitshuffle hdf5
    endif # ($(WITH_HDF5),YES)
  endif # ($(BITSHUFFLE_EXTERNAL),NO)
endif # ($(WITH_BITSHUFFLE),YES)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
I tried this rule, which would only work on Windows, but it did not work.
bitshuffle_hdf5.lib: bitshuffle.lib
Re: Makefile question Johnson, Andrew N. via Tech-talk
Prev: Re: AD R3-2 libzlib.so Siniša Veseli via Tech-talk
Next: Re: Makefile question Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
