Hi Iain,
On 12/11/18 1:20 PM, Iain Marcuson via Tech-talk wrote:
I was able to build the standalone sequencer fine. Yokogawa appears to build, but asyn fails with
make[4]: *** No rule to make target `ipSNCServer.o', needed by `libtestIPServerSupport.a'. Stop.
The sequencer provides its own set of build rules which the EPICS build system will pull in automatically from the sncseq module when you list it in your application's configure/RELEASE file. This isn't happening for you, and I suspect you're trying to use
a modified build system since you also wrote this earlier:
-snc binary in /opt/epics/bin/linux-arm
That isn't how the sequencer normally comes, GNUmake needs to see the contents of the sncseq/configure/RULES_BUILD file for any application that needs to compiler sequence programs.
- Andrew
- RE: FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Fw: Build failure when compiling synApps from source Mark Rivers via Tech-talk
- FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
RE: Build failure when compiling synApps from source Mark Rivers via Tech-talk
RE: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
ANJ, 11 Dec 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
