I had 80 char buffers when INP/OUT could be 78 chars.
ESS committed a fix to change the buffers to 256 in August 2018 to fit
EPICS 3.16 (?). This change is included in release 2.8.3.
In order to to fit "long pv names" generated by ESS site-specific
program (PLCFactory). We are using 3.15.5 as the base version.
That is not "perfect", but based on Base 3.15.5, 256 is good enough to
running IOC.
Best,
Han
With the unlimited link size in EPICS 7 any fixed buffer size is
obviously not sufficient. More important parsing it without length check
is not save any more.
I will change that.
Dirk
On 13.12.2018 16:55, Michael Davidsaver via Tech-talk wrote:
On 12/13/18 5:56 AM, Dirk Zimoch via Tech-talk wrote:
Hi William,
Even though the INP Length in EPICS 7 is not unlimited, StreamDevice
may nor be able to read it. 78 bytes was the effective limit of
INP/OUT in EPICS 3.14. Meanwhile I have changed my buffers from 80 to
256 bytes but not yet to "unlimited" (which is a bigger change).
In case someone is motived to help.
The buffers:
https://github.com/paulscherrerinstitute/StreamDevice/blob/acf7efcff2e29a997a5c2d21629d7ef64f1e19de/src/StreamEpics.cc#L536-L542
Parsing with sscanf()
https://github.com/paulscherrerinstitute/StreamDevice/blob/acf7efcff2e29a997a5c2d21629d7ef64f1e19de/src/StreamEpics.cc#L701-L753
However your string is cur at 78 chars like in EPICS 3.14.
I will check this with EPICS 7....
Dirk
On 13.12.2018 09:46, William Kirstaedter via Tech-talk wrote:
unlimited cant be the case, unfortunately. I'm running EPICS7 and
facing the following error when starting the IOC:
2018/12/13 09:42:51.409543 _main_ Missing ')' after substitutions
'readModule(EN,CRYVISIL:LEED:ENgain,CRYVISIL:LEED:ENoffset,CRYVISIL:LEED:ENvalue,LEED_01'
2018/12/13 09:42:51.409621 _main_ CRYVISIL:LEED:getEN: Protocol
parse error
2018/12/13 09:42:51.409642 _main_ CRYVISIL:LEED:getEN: Record
initialization failed
with these records and streamprotocol:
# Energy
record(stringin, "$(P):$(R):getEN") {
field(DTYP,"stream")
field(INP,"@leed.proto
readModule(EN,$(P):$(R):ENgain,$(P):$(R):ENoffset,$(P):$(R):ENvalue,$(P):$(R):ENmonitorU,$(P):$(R):ENmonitorI)
$(PORT)")
record(ai, "$(P):$(R):ENgain") {
field(DESC,"Energy Gain")
field(EGU,"eV")
field(PREC,"2")
record(ai, "$(P):$(R):ENoffset") {
field(DESC,"Energy Offset")
field(EGU,"eV")
field(PREC,"2")
record(ai, "$(P):$(R):ENvalue") {
field(DESC,"Energy Value")
field(EGU,"eV")
field(PREC,"2")
record(ai, "$(P):$(R):ENmonitorU") {
field(DESC,"Energy Voltage Monitor")
field(EGU,"eV")
field(PREC,"2")
record(ai, "$(P):$(R):ENmonitorI") {
field(DESC,"Energy Current Monitor")
field(PREC,"2")
field(EGU,"A")
OutTerminator= CR;
InTerminator= "\r\000\n>";
readModule{
# $1 : Module Name -> REN (read energy)
out"R\$1";
# answer: R $1 r NUL n $1 (what out "typed in" plus return)
$1|SP|GAIN|SP|OFFSET|SP|VALUE|SP|U-monitor|SP|I-monitor (the actual
answer)
# >REN
# EN +0 +500 +500 +500.85 +1.5653E-06
in"R\$1\r\000\n\$1%(\$2)f%(\$3)f%(\$4)f%(\$5)f%(\$6)f";
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail:[email protected]
Am 12.12.2018 um 17:29 schrieb Johnson, Andrew N.:
On 12/12/18 8:59 AM, William Kirstaedter via Tech-talk wrote:
Short Question:
Whats the maximum length of a record field? how many chars?
record(ai,"record_name"){
field(DESC, "I_mean_this")
field(INP, "how_long_can_this_be")
Longer answer:
That depends on the field definition for the record type. DESC is
defined in dbCommon.dbd (a kind of super-class used by all record
types) as:
field(DESC,DBF_STRING) {
prompt("Descriptor")
promptgroup("10 - Common")
size(41)
That means it's a DBF_STRING and the size() entry says it can hold
up to 41 characters, but there must be a zero-byte terminator so
the limit is really 40 (which matches the Channel Access
dbr_string_t typedef).
For something like the ZRST field of the mbbi record which defines
an enumeration string, the size is given as 26 which is the size of
the enumeration strings that Channel Access can send in a struct
dbr_gr_enum.
An INP or OUT field is a link and for these the maximum length
depends on the version of EPICS you're running; it might be 40 for
older versions, 80, 256 for some or unlimited for EPICS-7.
HTH,
- Andrew
- record field max length? William Kirstaedter via Tech-talk
- Re: record field max length? Johnson, Andrew N. via Tech-talk
- Re: record field max length? William Kirstaedter via Tech-talk
- Re: record field max length? Dirk Zimoch via Tech-talk
- Re: record field max length? Michael Davidsaver via Tech-talk
csm module support or alternative Davide Marcato via Tech-talk
Job opening at PSI Dirk Zimoch via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
