1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
Date: Thu, 20 Dec 2018 22:01:18 +0000
This thread moved off tech-talk for a while, but I’m putting it back in case someone has ideas.
My system and Russ’ appear to be the same, but he gets the error and I don’t.
Sent: Thursday, December 20, 2018 3:34 PM
Subject: Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
Yeah, I see the exact same search results.
Russ
Sent: Thursday, December 20, 2018 2:07 PM
To: Woods, Russell
Subject: RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
I’m quite sure I did not do what Matt Newville suggested, installing Pod::Simple::HTML because I would not have known how to do that.  And when I search for a file likely to be that in /usr/lib/perl5 I don’t see it.
lib/perl5> find . -name '*Pod*'
./5.8.8/Pod
./5.8.8/Pod/Perldoc/ToPod.pm
lib/perl5> find . -name '*Simple*'
./5.8.8/Filter/Simple.pm
./5.8.8/Test/Simple.pm
./vendor_perl/5.8.8/LWP/Simple.pm
lib/perl5> find . -name '*HTML*'
./vendor_perl/5.8.8/x86_64-linux-thread-multi/auto/HTML
./vendor_perl/5.8.8/x86_64-linux-thread-multi/HTML
./vendor_perl/5.8.8/Image/ExifTool/HTML.pm
./vendor_perl/5.8.8/Mail/SpamAssassin/HTML.pm
./vendor_perl/5.8.8/Mail/SpamAssassin/Plugin/HTMLEval.pm
./vendor_perl/5.8.8/HTML
What do you see when you do those searches?
I don’t know why it is working for me and not for you.
Sent: Thursday, December 20, 2018 1:56 PM
Thanks for checking Mark! Looks like you've compiled it on essentially the same computer.
Russ
Sent: Thursday, December 20, 2018 1:22 PM
To: Woods, Russell
Cc:
[email protected]
Hi Russ,
I have successfully built base 7.0.2 and all of synApps including areaDetector on my old openSUSE machines that run the Pilatus 100K detectors.
This is uname –a for that machine:
Linux gse-pilatus1 2.6.27.39-default #2 SMP PREEMPT Tue Dec 1 13:48:11 CET 2009 x86_64 x86_64 x86_64 GNU/Linux
It is perl 5.8.8 as you said:
/home/epics> perl --version
This is perl, v5.8.8 built for x86_64-linux-thread-multi
I thought I might have run into the error you are seeing when I first built 7.0.1.  But if I did I would have expected to find an e-mail to Andrew about the problem, and I can’t find one.
I don’t know enough about Perl to know what the problem might be.  Hopefully someone else will.
From: [email protected] <[email protected]> On Behalf Of Woods, Russell via Tech-talk
Sent: Thursday, December 20, 2018 12:18 PM
To:
[email protected]
Subject: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
Has anyone compiled base-7 on the OpenSUSE pilatus computers? I'm getting the error shown below. These computers have perl5.8.8
I didn't have any problem compiling on the newer CentOS 6.5 machines (perl5.10.1).
Thanks
Russ Woods
root:base-7.0.2# make
make -C ./configure install
make[1]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure'
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
        T_A=linux-x86_64 install
make[2]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure/O.linux-x86_64'
make[1]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure'
make -C ./src install
make[1]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src'
make -C ./tools install
make[2]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/convertRelease.pl
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/depclean.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't locate object method "new" via package "Pod::Simple::HTML" (perhaps you forgot to load "Pod::Simple::HTML"?) at ../../../src/tools/podToHtml.pl line 89.
make[3]: *** [../O.Common/EPICS/Getopts.html] Error 25
make[3]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools'
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src'
make: *** [src.install] Error 2
Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Woods, Russell via Tech-talk
RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Prev: Re: Stream fails on windows-x64 against base-7.0.2 Ralph Lange via Tech-talk
Next: RE: Stream fails on windows-x64 against base-7.0.2 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Matt Newville via Tech-talk
Next: Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
ANJ, 21 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
