1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Weird IOC behavior with NTP time shift
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Sun, 23 Dec 2018 13:55:55 +0000
Hi
This issue happened with base 3.14.12.3 and 3.15.6. What happened is that the IT group upgraded their MS windows active directory servers, one of the included services in the update is the NTP. When all the servers rebooted, the NTP service did not start and caused a 3-hour time shift forward in time on all connected PCs and hosts.
On the IOC side, when the shift happened the IOC date command returns the host's date/time. But when the problem was resolved by the IT group, the time got synchronized and went 3-hour backward in time. At this moment the date command returns the same timestamp, i.e., a frozen time stamp. We had to reboot every IOC to get the machine working.
My question is, is there any explanation for this behavior and any potential way to avoid it? Also on daylight saving times, we can't recall this issue happening on a DST switch before most probably because the machine was OFF, will DST switch give the same effect? The issue is reproducible with any IOC, whenever the IOC's timestamp is ahead of the host's time stamp, the IOC's timestamp will get frozen,
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Weird IOC behavior with NTP time shift Michael Davidsaver via Tech-talk
Prev: Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Johnson, Andrew N. via Tech-talk
Next: Re: Weird IOC behavior with NTP time shift Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Error when trying to build Sample IOC Application Harshal Sheth via Tech-talk
ANJ, 23 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
