On 12/23/18 5:55 AM, Abdalla Ahmad via Tech-talk wrote:
> Hi
> This issue happened with base 3.14.12.3 and 3.15.6. What happened is that the IT group upgraded their MS windows active directory servers, one of the included services in the update is the NTP. When all the servers rebooted, the NTP service did not start and caused a 3-hour time shift forward in time on all connected PCs and hosts.
> On the IOC side, when the shift happened the IOC date command returns the host's date/time. But when the problem was resolved by the IT group, the time got synchronized and went 3-hour backward in time. At this moment the date command returns the same timestamp, i.e., a frozen time stamp. We had to reboot every IOC to get the machine working.
> My question is, is there any explanation for this behavior and any potential way to avoid it? Also on daylight saving times, we can't recall this issue happening on a DST switch before most probably because the machine was OFF, will DST switch give the same effect? The issue is reproducible with any IOC, whenever the IOC's timestamp is ahead of the host's time stamp, the IOC's timestamp will get frozen,
What you describe is a known issue with IOC time handling which arises from the
(imo contradictory) requirement that epicsTimeGetCurrent() be monotonic.
The result is that after real time jumps backwards* calls to
epicsTimeGetCurrent() will return the same value until the OS clock
"catches up" with it's previous value.
https://github.com/epics-base/epics-base/blob/5f46d6dceed6c10c43ed5db0543979d696f1becd/src/libCom/osi/epicsGeneralTime.c#L162
As you've found, epicsTimeGetCurrent() is used internally in several places,
most notably in timer queues. So the effects are quite noticeable...
https://bugs.launchpad.net/epics-base/+bug/1392516
I have a (very) long term plan to switch the timer queue and similar to
a true monotonic time source. Such a time source is available as of
Base 7.0.1 (cf. epicsMonotonicGet() ), so the next step is to replace
usages of epicsTimeGetCurrent() and epicsTime::getCurrent().
* Daylight savings time isn't implemented as a jump of the seconds counter.
Rather it is a change in the mapping between the seconds counter and
calendar/time of day.
- RE: Weird IOC behavior with NTP time shift Abdalla Ahmad via Tech-talk
- Weird IOC behavior with NTP time shift Abdalla Ahmad via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
