1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynError in write on Power PMAC IOC
From: Wayne Lewis via Tech-talk <[email protected]>
To: Chanaka <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Jan 2019 08:44:07 -0800
Hi Chanaka,
It turns out the compile problem was due to a change in the Event record
from EPICS base 3.14 to 3.15 (the .VAL field changed from epicsUInt16 to
char[40].
I have a new fix proposed in
https://github.com/waynelewis/pmac/tree/ppmac-ramfix2
I'll be submitting a pull request soon to get that into the main PMAC
repo.
Wayne
On Fri, Jan 04, 2019 at 04:59:40PM -0500, Chanaka wrote:
> Wayne, Thank you for sharing the information.
> Chanaka
> On Fri, Jan 4, 2019 at 4:42 PM Wayne Lewis <[email protected]> wrote:
> > Thanks for the update on the repository status Alan.
> > Chanaka, I've been able to run an IOC for a PowerPMAC using the DLS
> > code. I found one compile problem (CentOS7, gcc 4.8.5) and have proposed
> > a fix in https://github.com/waynelewis/pmac/tree/ppmac-ramfix
> > I'm not able to test that the fix works, but it does compile, and the
> > rest of the code works fine with the PowerPMAC across the asyn port
> > interface to gpascii.
> > Wayne
> > On Fri, Jan 04, 2019 at 04:27:14PM -0500, Chanaka wrote:
> > > Thank you, Guys. I will work on migrating to DLS version.
> > > Last night I ran test scans with 1 second period. The scans did not hang
> > > up. Will continue with a couple more test runs.
> > > Regards,
> > > Chanaka
> > > On Fri, Jan 4, 2019 at 7:45 AM [email protected] <
> > > > Hi all,
> > > > I agree with Giles completely.  The OS module is now out of date and
> > lacks
> > > > many features available from the new pmac module.  The old OS module
> > is for
> > > > powerPMAC only.  The new module works with powerPMAC and geobrick, the
> > > > communications layer has been re-written, dynamic parameters are
> > supported,
> > > > trajectory scanning is supported etc.
> > > > I have added a message to the README of the original OSL powerPMAC
> > module
> > > > to forward people to the Diamond version.
> > > > The direct answer to your question Giles is no, the dynamic parameter
> > > > feature is not implemented in the OS driver.
> > > > Thanks, Alan
> > > > ________________________________
> > > > From: Knap, Giles (DLSLtd,RAL,LSCI)
> > > > Sent: 03 January 2019 09:46:54
> > > > To: Wayne Lewis
> > > > Cc: Chanaka; [email protected]; Greer, Alan (OBS,RAL,DIA)
> > > > Hi Wayne,
> > > > The DLS support module can be used without any DLS specific
> > dependencies
> > > > and is the currently maintained module. The power pmac support in
> > > > https://github.com/dls-controls/pmac is based on
> > > > https://github.com/Observatory-Sciences/powerPMAC and the latter is
> > being
> > > > deprecated.
> > > > I'm not sure if the dynamic parameter feature I discussed is
> > implemented
> > > > in the OS driver. (Alan?)
> > > > Regards,
> > > > giles.
> > > > From: Wayne Lewis <[email protected]>
> > > > Sent: 02 January 2019 16:41:15
> > > > To: Knap, Giles (DLSLtd,RAL,LSCI)
> > > > Hi Giles, Chanaka,
> > > > I've also seen a similar error on the IOC console when using a
> > > > StreamDevice connection to the PowerPMAC.
> > > > I notice that there are (at least) two versions of PowerPMAC EPICS
> > > > support available:
> > > > A couple of questions:
> > > > - is the DLS version dependent on anything other than standard EPICS
> > > > base and modules?
> > > > - is the Observatory Sciences version still maintained and used?
> > > > Thanks,
> > > > Wayne
> > > > On Wed, Jan 02, 2019 at 10:08:14AM +0000, giles.knap--- via Tech-talk
> > > > wrote:
> > > > > Hi Chanaka,
> > > > > It appears that you are sharing the connection port with a stream
> > device
> > > > (in order to determine if PLC 15 is running)? I would not recommend
> > this.
> > > > Instead you can add a dynamic parameter to one of the poll loops so
> > that
> > > > the driver will monitor it for you and efficiently manage
> > communications
> > > > with the power pmac.
> > > > > In this case you could use
> > > > > record(longin, "$(P){$(DEV)}TrajInitPlc-Read")
> > > > >     field(DTYP, "asynInt32")
> > > > >     field(INP, "@asyn(PMAC_CONTROLLER,0)PMAC_VIM_Plc[15].Running")
> > > > >     field(SCAN, "I/O Intr")
> > > > > This will update on the medium scan loop every 2 seconds. The slow
> > loop
> > > > is 5 seconds and the fast loop has two rates, idle and moving, which
> > are
> > > > specified as parameters to pmacController constructor.
> > > > > You should replace all of you protocol functions with a similar
> > pattern.
> > > > > I do not think the documentation covers dynamic parameters as yet,
> > but
> > > > the comments under pmacController::drvUserCreate give the following
> > details:
> > > > > // Accepted parameter formats
> > > > > // For reading variables
> > > > > // PMAC_VxF_...  => PMAC Variable Fast Loop
> > > > > // PMAC_VxM_...  => PMAC Variable Medium Loop
> > > > > // PMAC_VxS_...  => PMAC Variable Slow Loop
> > > > > // x is I for int, H for hex, D for double or S for string
> > > > > // There must be no j or = in a variable, these items will simply be
> > > > polled for their current status
> > > > > // For Writing only
> > > > > // PMAC_WI_... => Write Integer Value
> > > > > // PMAC_WD_... => Write Double Value
> > > > > // PMAC_WS_... => Write String Value
> > > > > // Writing to these parameters will result in immediate writes to the
> > > > PMAC
> > > > > ( One of the main goals of the pmac driver is to efficiently manage
> > > > communications with the hardware. We have a message broker that
> > batches up
> > > > all requests to poll for values into the 3 poll loops, the responses
> > are
> > > > distributed to any objects that have registered interest. There is
> > only one
> > > > instance of the message broker and it is the only object that
> > communicates
> > > > with the hardware. Thus requests through drvAsynPowerPMACPort are on a
> > > > single thread. If you share the drvAsynPowerPMACPort with a stream
> > device
> > > > then it will be being called on more than one thread. It should be
> > using
> > > > locking and should work but has not been tested in this fashion. )
> > > > > Regards,
> > > > > giles.
> > > > > From: [email protected] <[email protected]>
> > on
> > > > behalf of Chanaka via Tech-talk <[email protected]>
> > > > > Sent: 31 December 2018 16:03:40
> > > > > To: [email protected]
> > > > > Subject: asynError in write on Power PMAC IOC
> > > > > Dear All,
> > > > > I am running into a hanging issue while performing scans using higher
> > > > level software due to a WRITE INVALID caused by lower-level EPICS PVs.
> > The
> > > > occurrence is intermittent. From what I can find on line this *could*
> > be
> > > > due to how SCAN filed is setup in this database for the relevant PVs.
> > I am
> > > > not entirely sure if that could be the case. Any help would be
> > appreciated.
> > > > > --The specific error I see in the IOC shell is the following. This is
> > > > for one of the PVs.
> > > > > 2018/12/28 17:46:07.974527 SSH1 XF:07BMA-OP{MC:03}TrajInitPlc-Read:
> > > > asynError in write: 10.7.130.93 write error
> > > > > --And camonitor returned the following.
> > > > > XF:07BMA-OP{MC:03}TrajInitPlc-Read 2018-12-28 17:46:07.974595 0 WRITE
> > > > INVALID
> > > > > --The PV is defined as follows.
> > > > > record(ai, "$(P){$(DEV)}TrajInitPlc-Read")
> > > > >     field(DTYP, "stream")
> > > > >     field(INP,     "@ppmac_stream.proto getVarInt(Plc[15].Running)
> > > > $(SSH)")
> > > > >     field(SCAN, "0.5 second")
> > > > > -- getVarInt is defined as follows
> > > > > getVarInt{
> > > > >     out "\$1";
> > > > >     in "\n\$1=%d";
> > > > > -- Port configuration is as follows
> > > > > drvAsynPowerPMACPortConfigure("SSH1", "10.7.130.93", "root",
> > "deltatau",
> > > > "0", "0", "0")
> > > > > Thank you,
> > > > > Chanaka De Silva
> > > > > NSLSII
> > > > > This e-mail and any attachments may contain confidential, copyright
> > and
> > > > or privileged material, and are for the use of the intended addressee
> > only.
> > > > If you are not the intended addressee or an authorised recipient of the
> > > > addressee please notify us of receipt by returning the e-mail and do
> > not
> > > > use, copy, retain, distribute or disclose the information in or
> > attached to
> > > > the e-mail.
> > > > > Any opinions expressed within this e-mail are those of the individual
> > > > and not necessarily of Diamond Light Source Ltd.
> > > > > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > > > attachments are free from viruses and we cannot accept liability for
> > any
> > > > damage which you may sustain as a result of software viruses which may
> > be
> > > > transmitted in or with the message.
> > > > > Diamond Light Source Limited (company no. 4375679). Registered in
> > > > England and Wales with its registered office at Diamond House, Harwell
> > > > Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
> > Kingdom
> > > >   Wayne Lewis
> > > >   e: [email protected]
> > > >   w: http://ospreydcs.com
> > > >   p: +1 631 905 1964
> >   Wayne Lewis
> >   p: +1 631 905 1964
  Wayne Lewis
  p: +1 631 905 1964
Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
Re: asynError in write on Power PMAC IOC giles.knap--- via Tech-talk
Re: asynError in write on Power PMAC IOC Wayne Lewis via Tech-talk
Re: asynError in write on Power PMAC IOC alan.greer--- via Tech-talk
Prev: RE: asynDriver - UDP server Joao Afonso via Tech-talk
Next: Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
ANJ, 09 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
