1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: Cannot execute application on ARM target
To: "williams jr., ernest l." <[email protected]>
Date: Sun, 13 Jan 2019 10:57:19 +0800 (GMT+08:00)
-----原始邮件-----
发件人:"Williams Jr., Ernest L." <[email protected]>
发送时间:2019-01-11 23:52:15 (星期五)
收件人: "刘佳" <[email protected]>
抄送: "[email protected]" <[email protected]>
主题: Re: Cannot execute application on ARM target
Yes, I built the IOC application via the EPICS templates:
    makeBaseApp.pl -t example armexample
    makeBaseApp.pl -i -t example armexample ( the architechture choose linux-arm, and the application name is armexample)
I didn't change any configuration of the application, and then MAKE is no error. So I copy the <appTop> to the target.
when I try to start the application on the target,   ../../bin/linux-arm/armexample st.cmd,    the Error is:
-bash: ../../bin/linux-arm/armexample: No such file or directory
and then I change to the <appTop>/bin/linux-arm/, chmod +x armexample, and ./armexample, the Error is:
-bash: ./armexample: No such file or directory
I didn't known what to do next, please give some advices, thanks a lot!
Jia LIU
From: [email protected] <[email protected]> on behalf of 刘佳 via Tech-talk <[email protected]>
Sent: Thursday, January 10, 2019 6:59 PM
To: [email protected]
Subject: Cannot execute application on ARM target
I am trying to build EPICS application on ARM target, and the cross compiling on host have no error,
but the IOC on the target cannot execute:
[Ernest]:
If you are building  your IOC application via the EPICS Templates, then executable is found here by default:
<TOP>/bin/<T_A>/armexample
For example, I built and application called "Jupiter" for a linux target:
<TOP>/bin/rhel6-x86_64/Jupiter
Please provide more information such as did you first create a skeleton for you app with:
my configuration as following:
    HOST: Ubuntu 14.04 (on VMware)
    TARGET: Exynos4412
    BASE: base-3.14.12.5
    GCC: arm-none-linux-gnueabi-gcc-4.4.1
the cross compiling configuration is:
    configure/CONFIG_SITE:
        CROSS_COMPILER_TARGET_ARCHS=linux-arm
        CROSS_COMPILER_HOST_ARCHS=linux-x86
        SHARED_LIBRARIES=NO
        STATIC_BUILD=YES
    configure/os/CONFIG_SITE.Common.linux-arm:
        #COMMANDLINE_LIBRARY = READLINE
    configure/os/CONFIG_SITE.linux-x86.linux-arm:
        GNU_DIR = /opt/armtoolchain/arm-2009q3
        GNU_TARGET = arm-none-linux-gnueabi
the .bashrc configuration is:
    export EPICS_HOST_ARCH=linux-x86
    export EPICS_BASE=/home/control/epics/base-3.14.12.5
    export LD_LIBRARY_PATH=/opt/armtoolchain/arm-2009q3/lib:$EPICS_BASE/lib/linux-arm
I am still getting the error message on target, Please solve my above query.
Thanks
Jia LIU
Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
Cannot execute application on ARM target 刘佳 via Tech-talk
Prev: Re: Stanford Research Drivers Eric Norum via Tech-talk
Next: Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
ANJ, 12 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
