> I will consider the phyton solutions, but I agree the cronjob is an easy and elegant solution.
A cron job that periodically fetches your data and then calls `caput SomeRecord ThatData` is certainly a very easy way to get started. It's perfectly fine if you run that cronjob once an hour.
It would be bad to run such a setup every few seconds, because each call to caput will send a name search, establish the network connection, write a value, disconnect, ... and then do the same a second later.
For that scenario, a python script that uses PyEpics as a client would be much better:
from time import sleep
from epics import caput
while True:
# .. somehow get your data ..
caput('SomePV', that_data)
sleep(1)
The Pyepics `caput` will under the hood only connect once and then keep reusing that connection.
Or look at PCASPY to create a CA server in python.
Kay
- Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
- Re: Getting data from a shell script into an ioc Pearson, Matthew R. via Tech-talk
- Re: Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
Problem in Stream Out of two 8 bit data Ashish Sharma via Tech-talk
EPICS in Docker containers Gabriel de Souza Fedel via Tech-talk
<2019>
2025
2026
Re: Getting data from a shell script into an ioc Sebastian Marsching via Tech-talk
<2019>
2025
2026
