1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting data from a shell script into an ioc
From: Sebastian Marsching via Tech-talk <[email protected]>
To: Bo Jakobsen <[email protected]>
Date: Sat, 23 Feb 2019 11:34:22 +0100
I was wondering if it is possible to use the streamDevice framework to call a shell script on the IOC host and then process the output. That would be a very easy way to make simple connections to existing programs.
What would be the best approach?
I know I am late to the party, but I still wanted to point you to a solution that might fit exactly what you originally asked for.
The Execute device support (https://github.com/KIT-IBPT/epics-execute) does exactly that: It allows you to run a shell script (or any executable for that matter) and makes the exit code and output available in EPICS records.
Whether this is the best solution for you, or the other solutions (socket server with StreamDevice, Python scripts with pyDevSup) are better for you of course depends on the details of your requirements.
Cheers,
Sebastian
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Getting data from a shell script into an ioc Pierrick M Hanlet via Tech-talk
Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
Prev: Re: GNU Screen or procServ on ARM? Mark Rivers via Tech-talk
Next: Re: Getting data from a shell script into an ioc Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Getting data from a shell script into an ioc Kasemir, Kay via Tech-talk
ANJ, 23 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
