1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem compiling EPICS base R3.14.12.7 under RTEMS
From: Michael Westfall via Tech-talk <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Wed, 16 Jan 2019 11:17:44 -0300
Thanks, that's what worked.
On Wed, Jan 16, 2019 at 11:03 AM Heinz P. Junkes via Tech-talk <[email protected]> wrote:
 RTEMS changed the API
Please apply the following patch
diff --git a/modules/libcom/src/osi/os/RTEMS/osdThread.c b/modules/libcom/src/osi/os/RTEMS/osdThread.c
index 769e958..2db1ca5 100644
--- a/modules/libcom/src/osi/os/RTEMS/osdThread.c
+++ b/modules/libcom/src/osi/os/RTEMS/osdThread.c
@@ -640,17 +640,17 @@ showInternalTaskInfo (rtems_id tid)
      * that priority should be displayed, not the value truncated to
      * the EPICS range.
-    epicsPri = 199-thread.real_priority;
+    epicsPri = 199-thread.Priority_node.real_priority;
     if (epicsPri < 0)
         fprintf(epicsGetStdout(),"   <0");
     else if (epicsPri > 99)
         fprintf(epicsGetStdout(),"  >99");
     else
         fprintf(epicsGetStdout()," %4d", epicsPri);
-    if (thread.current_priority == thread.real_priority)
-        fprintf(epicsGetStdout(),"%4d    ", (int)thread.current_priority);
+    if (thread.Priority_node.current_priority == thread.Priority_node.real_priority)
+        fprintf(epicsGetStdout(),"%4d    ", (int)thread.Priority_node.current_priority);
     else
-        fprintf(epicsGetStdout(),"%4d/%-3d", (int)thread.real_priority, (int)thread.current_priority);
+        fprintf(epicsGetStdout(),"%4d/%-3d", (int)thread.Priority_node.real_priority, (int)thread.Priority_node.current_priority);
     showBitmap (bitbuf, thread.current_state, taskState);
     fprintf(epicsGetStdout(),"%8.8s", bitbuf);
     if (thread.current_state & (STATES_WAITING_FOR_SEMAPHORE |
Heinz
On 1/16/19 2:51 PM, Michael Westfall via Tech-talk wrote:
When compiling base R3.14.12.7 for RTEMS 4.10.2, I get the following error:
/gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=7400 -D__ppc_generic                   -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS -I/gem_swdev1/epics/R3.14.12.7/base/include         ../../../src/libCom/osi/os/RTEMS/osdThread.c
../../../src/libCom/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error: 'Thread_Control' has no member named 'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'current_priority'
make[3]: *** [osdThread.o] Error 1
make[3]: Leaving directory `/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src/libCom/O.RTEMS-beatnik'
make[2]: *** [install.RTEMS-beatnik] Error 2
make[2]: Leaving directory `/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src'
make: *** [src.install] Error 2
What did I forget to do in my RTEMS setup?
Mike Westfall
Control Systems Software Engineer
Mike Westfall
Problem compiling EPICS base R3.14.12.7 under RTEMS Michael Westfall via Tech-talk
Re: Problem compiling EPICS base R3.14.12.7 under RTEMS Heinz P. Junkes via Tech-talk
Prev: Re: Problem compiling EPICS base R3.14.12.7 under RTEMS Heinz P. Junkes via Tech-talk
Next: Please use a relevent subject line Géraldine BOUCHER via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 16 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
