Subject: |
Re: Problem compiling EPICS base R3.14.12.7 under RTEMS |
"Heinz P. Junkes via Tech-talk" <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 16 Jan 2019 15:02:51 +0100 |
RTEMS changed the API
Please apply the following patch
diff --git a/modules/libcom/src/osi/os/RTEMS/osdThread.c
b/modules/libcom/src/osi/os/RTEMS/osdThread.c
index 769e958..2db1ca5 100644
--- a/modules/libcom/src/osi/os/RTEMS/osdThread.c
+++ b/modules/libcom/src/osi/os/RTEMS/osdThread.c
@@ -640,17 +640,17 @@ showInternalTaskInfo (rtems_id tid)
* that priority should be displayed, not the value truncated
to
* the EPICS range.
- epicsPri = 199-thread.real_priority;
+ epicsPri = 199-thread.Priority_node.real_priority;
if (epicsPri < 0)
fprintf(epicsGetStdout()," <0");
else if (epicsPri > 99)
fprintf(epicsGetStdout()," >99");
else
fprintf(epicsGetStdout()," %4d", epicsPri);
- if (thread.current_priority == thread.real_priority)
- fprintf(epicsGetStdout(),"%4d ",
(int)thread.current_priority);
+ if (thread.Priority_node.current_priority ==
thread.Priority_node.real_priority)
+ fprintf(epicsGetStdout(),"%4d ",
(int)thread.Priority_node.current_priority);
else
- fprintf(epicsGetStdout(),"%4d/%-3d",
(int)thread.real_priority, (int)thread.current_priority);
+ fprintf(epicsGetStdout(),"%4d/%-3d",
(int)thread.Priority_node.real_priority,
showBitmap (bitbuf, thread.current_state, taskState);
fprintf(epicsGetStdout(),"%8.8s", bitbuf);
if (thread.current_state & (STATES_WAITING_FOR_SEMAPHORE
Heinz
On 1/16/19 2:51 PM, Michael Westfall
via Tech-talk wrote:
When compiling base R3.14.12.7 for RTEMS 4.10.2,
I get the following error:
/gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc
--pipe
-B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/
-specs bsp_specs -qrtems -fasm -c -mcpu=7400
-D__ppc_generic -DUNIX -O2 -g
-g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD
-DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048
-DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -MMD -I.
-I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS
-I../../../src/libCom/osi/os/posix
-I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib
-I../../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd
-I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error
-I../../../src/libCom/fdmgr
-I../../../src/libCom/freeList
-I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh
-I../../../src/libCom/logClient
-I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd
-I../../../src/libCom/timer
-I../../../src/libCom/tsDefs
-I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS
../../../src/libCom/osi/os/RTEMS/osdThread.c
../../../src/libCom/osi/os/RTEMS/osdThread.c:
In function 'showInternalTaskInfo':
../../../src/libCom/osi/os/RTEMS/osdThread.c:617:
error: 'Thread_Control' has no member named
'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:624:
'current_priority'
'real_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:625:
'current_priority'
../../../src/libCom/osi/os/RTEMS/osdThread.c:627:
'real_priority'
'current_priority'
make[3]: *** [osdThread.o] Error 1
make[3]: Leaving directory
`/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src/libCom/O.RTEMS-beatnik'
make[2]: *** [install.RTEMS-beatnik] Error 2
make[2]: Leaving directory
`/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory
`/gem_swdev1/epics/R3.14.12.7/epics-base-R3.14.12.7/src'
make: *** [src.install] Error 2
What did I forget to do in my RTEMS setup?
Mike Westfall
Control Systems Software Engineer
- Re: Problem compiling EPICS base R3.14.12.7 under RTEMS Michael Westfall via Tech-talk
- Problem compiling EPICS base R3.14.12.7 under RTEMS Michael Westfall via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 16 Jan 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
