1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Please use a relevent subject line
From: bob dalesio via Tech-talk <[email protected]>
To: Géraldine BOUCHER <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 16 Jan 2019 12:14:52 -0500
Binary Outputs have a field HIGH - that is how long to keep the value high. You can use any widget that would set the VAL field of a BO record. The record itself will turn the value back off after the value set in HIGH.
Bob
On Wed, Jan 16, 2019 at 12:11 PM Géraldine BOUCHER via Tech-talk <[email protected]> wrote:
I use the software CS-Studio in my internship. I would like to realize a
connection between a timer and a boolean (switch).
I would like that when I push on the start button of the timer, the switch
actually visually switches on, like from dark to blight. I don't know if I
have to use Action, Rules or Scripts for this.
 Because when I look for it in examples for switch and LED, I don't see a
link beetwen the 2, there is no rules, no action and no scripts to do so.
I feel that it's easy but I'm blocked.
Best,
Géraldine Boucher
Please use a relevent subject line Géraldine BOUCHER via Tech-talk
Prev: Re: How to pick up value of environment variable in /configure/RELEASE? Davide Marcato via Tech-talk
Next: Re: How to pick up value of environment variable in /configure/RELEASE? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Please use a relevent subject line Géraldine BOUCHER via Tech-talk
Next: Re: SPEC "can't get a big memory buffer" issue Mark Rivers via Tech-talk
ANJ, 17 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
