1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: How to pick up value of environment variable in /configure/RELEASE?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Wed, 16 Jan 2019 17:40:45 +0000
Hi Mike,
On 1/15/19 7:57 PM, Michael Westfall via Tech-talk wrote:
> For example, if I currently have:
> EPICS_BASE=/my_epics_location/epics/R3.14.12.7/base
> but I want to be able to change the location of /my_epics_locationon
> the fly  (perhaps because I want to use a different version of EPIS)
> by setting an environment variable $MY_EPICS_LOCATION,
> then how would I pick up the environment variable value in
> configure/RELEASE?
> I feel like I should know this, but I guess I haven't ever had reason
> to do it before.
The basic EPICS build system was designed explicitly to *not* take
RELEASE paths from the build-time environment, as that makes the build
process potentially unrepeatable. At the APS and many other sites we
expect to be able to revert our operational IOCs to an older version
that might depend on different support modules just by checking out the
files for that version of the IOC and running 'make'. Any EPICS
developer should also be able to replicate a build the same way
irrespective of their current environment, but this wouldn't work if
environment variables could override the settings in the RELEASE files.
You can define and use variables in your RELEASE files and even include
other files, but you would still have to modify at least one line of one
file to switch to a different Base version (and change the paths for any
other dependent modules at the same time). Synapps includes a
configuration management system that modifies RELEASE files, and BESSY
publish a tool called SUMO which can check out and build a complete set
of dependent modules for you, including reusing any modules that have
already been built for the desired configuration.
Other sites have developed alternative approaches and made local changes
to the code for their approach to builds, but I don't think the current
approach is likely to be changed in the EPICS core build system
until/unless someone else takes over maintenance of it.
- Andrew
Re: How to pick up value of environment variable in /configure/RELEASE? Michael Westfall via Tech-talk
Prev: Re: Please use a relevent subject line bob dalesio via Tech-talk
Next: Re: How to pick up value of environment variable in /configure/RELEASE? Michael Westfall via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: How to pick up value of environment variable in /configure/RELEASE? Davide Marcato via Tech-talk
ANJ, 16 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
