You need to edit the startup script and use a different database from the one used for TTL control.
Sent from my iPhone
On Jan 17, 2019, at 2:21 AM, "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> wrote:
So are you infering that I can achieve RS-232 control by simply editing the startup script?
Zhibang Shen
Date: 2019-01-16 19:55
To: [email protected]<mailto:[email protected]>
CC: [email protected]<mailto:[email protected]>
Subject: Re: How to use synApps optics module to control XIA pf4 filter
I think the example startup scripts are for TTL control, not for RS-232.
Sent from my iPhone
On Jan 16, 2019, at 8:51 AM, "[email protected]<mailto:[email protected]><mailto:[email protected]>" <[email protected]<mailto:[email protected]><mailto:[email protected]>> wrote:
I am trying to use RS232. But I didn't find the serial port configuration command in the startup script.
Zhibang Shen
Date: 2019-01-16 15:00
To: Zhibang Shen<mailto:[email protected]>
There are 2 ways to control the PF4. One is via TTL control lines. The other is via RS-232. Which are you trying to use?
From: [email protected]<mailto:[email protected]><mailto:[email protected]> <[email protected]<mailto:[email protected]><mailto:[email protected]>> on behalf of Zhibang Shen via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>>
Sent: Tuesday, January 15, 2019 9:32 PM
To: [email protected]<mailto:[email protected]><mailto:[email protected]>
Subject: How to use synApps optics module to control XIA pf4 filter
I am trying to use synApps optics module to control XIA pf4 filter. I have made the module and ran the code without error. SynApps xxx module could also be started to access to the PVs. However, pf4 filter did not work because I did not make any configuration about the ip address or serial port. I even didn't edit any code. I want to use local serial port to connect the host computer and pf4 filter. But I don't know how it works nor whether it works. I searched the startup script for hardware configure code like drvAsynIPPortConfigure or drvAsynSerialPortConfigure and I failed. So I would like someone to help me with the confusion.
Thanks a lot.
Zhibang Shen
Institute of High Energy Physics, Chinese Academy of Sciences
19B Yuquan Road, Shijingshan District, Beijing, China
100049
- How to use synApps optics module to control XIA pf4 filter Zhibang Shen via Tech-talk
- Re: How to use synApps optics module to control XIA pf4 filter Mark Rivers via Tech-talk
- Re: Re: How to use synApps optics module to control XIA pf4 filter shenzb--- via Tech-talk
Re: SPEC "can't get a big memory buffer" issue Mark Rivers via Tech-talk
<2019>
2025
2026
Problem compiling EPICS base R3.14.12.7 under RTEMS Michael Westfall via Tech-talk
<2019>
2025
2026
