1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: webEPICS
From: Hinko Kocevar via Tech-talk <[email protected]>
Date: Tue, 22 Jan 2019 10:37:18 +0000
Hi Andrew,
On 2019-01-21 18:10:15+01:00 [email protected] wrote:
Hi Hinko,
&amp;gt; plotting available.
If there was a server-side data cache in the original it was probably
there to prevent a DoS attack from outside reaching into the control
If I understood the code correctly, webEPICS was taking the OPI/BOB files, generating the HTML/JS and cache the results so that it did not have to convert the OPI to HTML for every request.
system network in the event that someone were to send a large number of
requests to the web-server all at once. For your status page, does each
web-client result in a separate pyepics process being started (or cause
a new set of CA-searches or CA-gets to be triggered)? Hopefully you have
some kind of rate limit in place to prevent DoS attacks...
I'm not that familiar with all the underlying mechanism regarding the CA protocol and what happens when a new client appears. Thanks for pointing it out, I need some investigating to do!
DoS - good point. We will need to make it more resilient to such attacks, because I see many script kiddies trying to perform their kung-fu against the server. And there are no rate limiters or similar in place, not at the moment.
Hinko
- Andrew
RE: webEPICS Hinko Kocevar via Tech-talk
Re: webEPICS Johnson, Andrew N. via Tech-talk
Prev: RE: Cable Management Applications Recommendations Hinko Kocevar via Tech-talk
Next: Re: Simple alarm monitor Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: webEPICS Johnson, Andrew N. via Tech-talk
Next: AreaDetector Code Not Updating Iain Marcuson via Tech-talk
ANJ, 22 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
