1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: webEPICS
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 21 Jan 2019 17:09:58 +0000
Hi Hinko,
On 1/21/19 7:13 AM, Hinko Kocevar via Tech-talk wrote:
> since you pointed me to webEPICS a while ago, we at ESS, managed to
> come up with this little status page:
> http://ics-webread01.esss.lu.se/index.html
> It show proton count trends and BCM current trace (our ion source is
> currently off).
> The code is a fork of webEPICS from github, adopted for EPICSv3 (using
> pyepics).
> My code does not deal with caches and/or converting OPI/BOB to
> HTML/JS/CSS. Instead we opted for having a predefined, simple web
> page that could be extended/reused. There is also a plotly trace
> plotting available.
If there was a server-side data cache in the original it was probably
there to prevent a DoS attack from outside reaching into the control
system network in the event that someone were to send a large number of
requests to the web-server all at once. For your status page, does each
web-client result in a separate pyepics process being started (or cause
a new set of CA-searches or CA-gets to be triggered)? Hopefully you have
some kind of rate limit in place to prevent DoS attacks...
- Andrew
RE: webEPICS Hinko Kocevar via Tech-talk
Prev: RE: webEPICS Hinko Kocevar via Tech-talk
Next: AreaDetector Code Not Updating Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: RE: webEPICS Hinko Kocevar via Tech-talk
ANJ, 22 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
