1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Simple alarm monitor
From: Maren Purves via Tech-talk <[email protected]>
To: Rolf Keitel <[email protected]>, Bo Jakobsen <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 23 Jan 2019 11:32:09 -1000
We run alh here (to send email, the 'user interface' is on a virtual
display that nobody looks at) and it works fine on CentOS5 and CentOS6
(with EPICS 3.13.8 ...)
I may try out your new one, Rolf, thanks for that!
Maren Purves
East Asian Observatory
On 1/23/19 09:52, Rolf Keitel via Tech-talk wrote:
Hi Bo,
You don’t say what platform you want to run this on.
The old EPICS alarm handler alh, a standard EPICS extension would do what you want (alh is using Motif, but not maintained any more).
https://epics.anl.gov/extensions/alh/index.php
We have a fully alh-compatible alarm handler which uses Qt. It is run here as the production alarm handler.
http://isacwserv.triumf.ca/epics/TAlh/
- rolf -
Rolf Keitel, Ph.D
TRIUMF, 4004 Wesbrook Mall
Vancouver, BC, V6T 2A3
Tel.: 604 222 7453
e-mail: [email protected] <mailto:[email protected]>
*From:*[email protected] <[email protected]> *On Behalf Of *Bo Jakobsen via Tech-talk
*Sent:* January 22, 2019 2:00 AM
*To:* [email protected]
*Subject:* Simple alarm monitor
Hi all
I am looking for a "simple alarm monitor".
The ones I found all seems to be to large a framework to set up for what I am trying to do on a small scale.
I would just like a monitor program which monitors a small number of PV's (order of 50)
* Writes to a log when the PV goes into or out of Alarm status
* Potentially can call a external program the an alarm happens (for e.g. sending a text messeage or mail).
I was considering to write something in python, but if something like this already exists that would be easier :-)
Best
Bo
Re: Simple alarm monitor Bo Jakobsen via Tech-talk
RE: Simple alarm monitor Rolf Keitel via Tech-talk
Prev: Raspberry Pi 3 B+ Control System Studio Kevin Ramos via Tech-talk
Next: RE: Segmentation Fault when exiting certain Area Detector Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: Simple alarm monitor Rolf Keitel via Tech-talk
Next: Re: Simple alarm monitor Bo Jakobsen via Tech-talk
ANJ, 24 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
