1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Searching for Stream device db/proto for Lakeshore 331 temp controller
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: Heinz Junkes <[email protected]>, Tech-talk <[email protected]>
Date: Thu, 24 Jan 2019 22:01:31 +0000
The EPICS ip module has non-stream support for the LakeShore 331:
   https://github.com/epics-modules/ip/blob/master/ipApp/Db/LakeShore331.db
It has stream support for the LakeShore 335 and 336.
Kevin
On 1/24/19 1:47 PM, Heinz Junkes via Tech-talk wrote:
> Is there a stream device db/proto available for the Lakeshore 331 temperature controller.
> Danke,
> Heinz
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        |
> D - 14195 Berlin        | E-Mail:[email protected]
RE: Searching for Stream device db/proto for Lakeshore 331 temp controller Kathryn Baker - UKRI STFC via Tech-talk
Searching for Stream device db/proto for Lakeshore 331 temp controller Heinz Junkes via Tech-talk
Prev: Re: Raspberry Pi 3 B+ Control System Studio Kevin Ramos via Tech-talk
Next: RE: Searching for Stream device db/proto for Lakeshore 331 temp controller Kathryn Baker - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Searching for Stream device db/proto for Lakeshore 331 temp controller Heinz Junkes via Tech-talk
ANJ, 25 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
