1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Searching for Stream device db/proto for Lakeshore 331 temp controller
From: Kathryn Baker - UKRI STFC via Tech-talk <[email protected]>
Date: Fri, 25 Jan 2019 09:59:38 +0000
If you want stream then the 336 is included here https://github.com/ISISComputingGroup/EPICS-lakeshore from our code - based on work by ORNL and Diamond from a quick glance.
Kathryn
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Peterson, Kevin M. via Tech-talk
Sent: 24 January 2019 22:02
To: Heinz Junkes <[email protected]>; Tech-talk <[email protected]>
Subject: Re: Searching for Stream device db/proto for Lakeshore 331 temp controller
The EPICS ip module has non-stream support for the LakeShore 331:
   https://github.com/epics-modules/ip/blob/master/ipApp/Db/LakeShore331.db
It has stream support for the LakeShore 335 and 336.
Kevin
On 1/24/19 1:47 PM, Heinz Junkes via Tech-talk wrote:
> Is there a stream device db/proto available for the Lakeshore 331 temperature controller.
> Danke,
> Heinz
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        |
> D - 14195 Berlin        | E-Mail:[email protected]
Searching for Stream device db/proto for Lakeshore 331 temp controller Heinz Junkes via Tech-talk
Re: Searching for Stream device db/proto for Lakeshore 331 temp controller Peterson, Kevin M. via Tech-talk
Prev: Re: Searching for Stream device db/proto for Lakeshore 331 temp controller Peterson, Kevin M. via Tech-talk
Next: softgluezynq Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 25 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
